H-H Series/Parallel w/ coil tap - Jemsite
post #1 of 1 (permalink) Old 04-18-2010, 04:30 PM Thread Starter
Ok, so I'm in a bit of a pickle:
Since the JS series are the best guitars ever, I want to make mine even better.
Base Info: JS100 H/H with a push/pull coil tap. Two DiMarzio Evo's installed. I have already installed one DPDT toggle on/on (no middle position) switch, second one to follow once I know what i'm doing.
I'm trying to wire my bridge PU for series/parallel. I've looked at a whole lot of different resources and wiring diagrams, and I cant find one that makes any sense for this configuration.
The way it is currently wired is cutoff/series 0_0 , so I know I've done something wrong.
I assume the conductor wires should go to the DPDT before it's connected to the coil tap, but i truly have no idea.
Can anyone help?
ekhan is offline
coil tap , dimarzio , satriani , series/parallel
Coil Split vs Parallel Configuration Yamadron Pickups & wiring 6 02-05-2010 04:16 PM
Parallel vs. coil split forest4 Pickups & wiring 3 01-30-2010 09:57 PM
coil split and parallel? Shredragrammaton Pickups & wiring 3 02-06-2009 11:06 PM
Series/parallel madness! Big Job Pickups & wiring 4 10-28-2005 12:04 PM
Coil Tap and Parallel? Shredcows Pickups & wiring 12 04-09-2005 12:19 AM
HTML code is On
