Hardware swap on JS neck? - Jemsite
post #1 of 5 (permalink) Old 03-13-2014, 11:12 PM Thread Starter
Ok so I have a JS100 neck that I want to use in a project.... I want to switch all hardware to Cosmo Black. The new body is routed for an Edge Pro Trem, which I have ordered from Ibanez with the correct 250mm JS Radius.
Question is, the only JS Nut thats Cosmo Black that I see on the Ibanez parts page is top mount, and the JS100 neck uses a bottom mount one..... can I just install a top mount one? is it easy to do?
Any other suggestions?
Sean777 is offline
post #2 of 5 (permalink) Old 03-13-2014, 11:34 PM
Reviews: 120
Re: Hardware swap on JS neck?
Fill the holes in the neck with dowel, and drill for the new top mount nut. That would be my guess.
LonePhantom is offline
post #3 of 5 (permalink) Old 03-13-2014, 11:42 PM
I just checked and the V nut holes are the same as the pad bolt holes and just not tapped. Tap them and you can bolt it on, but it's countersunk on the top so it only has half the threads thickness. Should be enough. If it's not you'll have to figure something else out.
Rich is offline
post #4 of 5 (permalink) Old 03-14-2014, 09:08 AM
jb4674's Avatar
Reviews: 18
Too much trouble to go through just to upgrade a JS100....
Leave the nut as is and continue modding everything else...
Jimmy
jb4674 is offline
post #5 of 5 (permalink) Old 03-14-2014, 10:01 PM Thread Starter
Cheers guys,
Its just a JS100 neck, it will be stripped, new fretboard and other bits and pieces... I ended up going with a chrome Edge Pro instead so matching nut was no prob
Sean777 is offline
hardware swap? my gold ibanez egen (edge zero) h/w for your cosmo h/w krylon Classified Ads: Guitars and Gear 3 05-01-2011 12:42 AM
JS Neck Swap - ??? jay ratkowski Ibanez JEM, UV, JS & Other Signature Models 3 12-12-2010 12:12 AM
SWAP: Jem neck 77FP tree of life and floral head for 777DY pyramid neck blitzmark1 Classified Ads: Guitars and Gear 2 03-19-2009 06:41 PM
fs Ibanez rgt42 body/neck neck thru no pup's or hardware gunkungfu Classified Ads: Guitars and Gear 5 09-15-2005 06:45 PM
HTML code is On
