Having to bend further to achieve the same note - Jemsite
post #1 of 5 (permalink) Old 03-09-2010, 11:00 PM Thread Starter
That probably isn't the best description....
... but essentially, I'm having to bend strings further on one of my JS's in order to achive a note I'd reach with less effort on the others. A 2 step bend really seems to be asking a lot
As the string guage and brand haven't changed is it a sign I need to change saddles, or trem springs or something?
Cheers
Joe Satrini is offline
post #2 of 5 (permalink) Old 03-09-2010, 11:29 PM
Re: Having to bend further to achieve the same note
are the springs worn out? is the trem really "loose"? a stiffer trem is easier to bend on etc.
Homebake is offline
post #3 of 5 (permalink) Old 03-10-2010, 03:53 AM Thread Starter
Doesn't seem any looser than the others. I suppose swapping in springs from one of those would help. Will try that - any other possibilities?
post #4 of 5 (permalink) Old 03-10-2010, 04:42 AM
JayRobIBZ's Avatar
Reviews: 3
Does the guitar in question and the guitars that you are comparing it to have the same specs? A trem with springs that give easier will require a larger bend to reach pitch because the trem is giving while you bend the string and you have to reach a point where the springs are providing enough resistance to provide enough string tension. Bla Bla Bla
There are other obvious reasons that will change the way that a string feels like scale length and string gauge. However, a less often thought about factor is locking nut versus non locking nut. With a non locking nut you are dealing with a longer amount of string that needs to stretch before you sufficiently raise the pitch.
Other than one of those few reasons I am not aware of any reason why your guitar should require a larger bend than any other.
JayRobIBZ is offline
post #5 of 5 (permalink) Old 03-10-2010, 12:42 PM Thread Starter
They're all JS Fujijen guitars. It is sounding like the springs must be giving more than I have realised so will try the swap out and see. Thanks for the advice
simplest way to achieve this setup Pewtershmit Gear, Equipment, Recording & Off Topic 2 11-21-2009 03:43 AM
note sounds :dead: Slight buzz only on the Low E string "C" note nighttraveler Tech: Setup, Repairs and Mods 1 06-11-2009 11:10 PM
Bad note!!! - bad note on JEM90 BenC Tech: Setup, Repairs and Mods 2 01-24-2002 05:15 PM
Note on 5th doesn't sound like the same note on 17th. - Why? ElhazGuy Tech: Setup, Repairs and Mods 16 01-16-2002 03:08 AM
Paul Gilbert - How to achieve tone... RSVampire Gear, Equipment, Recording & Off Topic 15 11-02-2001 02:28 AM
HTML code is On
