Help tuning my ibanez jem please - Jemsite
post #1 of 11 (permalink) Old 06-05-2011, 10:09 AM Thread Starter
Exclamation Help tuning my ibanez jem please
I made the mistake of tuning my Jem to Drop D for a song and now i want it back to standard as it's too much of a pain to keep changing it. Everytime i tune one string it sends the others out, how can i prevent this from happening so i can tune it? I saw some people talking about blocking the tremolo with something? any help is appreiciated thanks
dannyevers is offline
post #2 of 11 (permalink) Old 06-05-2011, 11:29 AM
Re: Help tuning my ibanez jem please
Reading through this might help. Tons of great resources there.
http://www.ibanezrules.com/tech/setup/tuning.htm
satchmo72 is offline
post #3 of 11 (permalink) Old 07-06-2011, 08:21 AM
Cool Article. I ran into a situation last night where everyone was down a Half Step and I was standard and it took forever to get it straight. I belive I may Need to release the tension on My springs some to level the bridge back out? Or move to a Heavier gauge. I use 9s -42 on My Jem. Since it is my primary gigging guitar and will be with the new group I just joined I am Just trying to consider the best option to take with this.
JAY
juggerfoot is offline
post #4 of 11 (permalink) Old 07-06-2011, 07:45 PM
metalhead52's Avatar
Just need 2 more guitars. One for each tuning. Keep the Jem at standard and get a couple of RG 5xx or 7xx for the other 2 tunings. Problem solved.
metalhead52 is offline
post #5 of 11 (permalink) Old 07-07-2011, 06:07 AM
I put 10s on my JEM and it set right back all pretty like.
post #6 of 11 (permalink) Old 07-07-2011, 09:16 AM
Reviews: 11
Metalhead is right, you should never try and change the tuning on your Jem while your gigging, it's practically impossible to do it fast.
Your gunna need a couple more axes, that's honestly the only solution.
As for changing the string/tuning etc, you need patience, and you need to learn to do it properly.
Bryancap77 is offline
post #7 of 11 (permalink) Old 07-07-2011, 09:37 AM
Yeah...I have four back ups to my Jem, But seeing how that is my Main gigging guitar I set it up with tens. The problem was real showing up to rehearse with these new guys and them forgetting to mention that they played everything a half down. So it took a good 45 minutes, as most of you with Floaters know, To get it set. Now that I moved to 10s and reset everything how I like it, It's all good. I was mainly exploring options before switching Gauge on it.
post #8 of 11 (permalink) Old 07-07-2011, 12:41 PM
My jem just suddenly dropped its tuning in a big way the other night. It was apparently set up by a proffesional luthier, can it be he didint tighten up the locking nuts enough?
Freaked me out, how do you know if the trem has moved somehow? is it only by eye?
I unlocked everything and spent some time and we are now back to tune and locked down tightly.
Phil
philster_d is offline
post #9 of 11 (permalink) Old 07-07-2011, 01:25 PM
I do the EVH thing of blocking all of my trems from pulling up. I just use a wood shim and some glue, and keep shaving the wood shim until it is just right. I can still use the bar for all of the dives and such, just no pull up. And best of all, I can alter tunings or whatever I want, even have a string break, and the other strings will stay in tune. In never like a completely floating bridge anyway, this is so much more stable and I still use the bar for everything I ever wanted to do with it.
lynchfan6 is offline
post #10 of 11 (permalink) Old 07-07-2011, 01:38 PM
Reviews: 11
TREMOL-NO SOLVES EVERYTHING!!! its expensive (about $70ish) but its way less expensive than a new guitar
D.M.RG7620 is offline
post #11 of 11 (permalink) Old 07-08-2011, 09:04 AM
true.
zombiecookie is offline
guitar , ibanez , jem , tuning
Similar Searches
Ibanez Tuning Pegs whitestrat All Other Guitars (including Prestige) 0 06-21-2009 08:47 AM
Tuning an Ibanez SV5470F PaulyWally All Other Guitars (including Prestige) 2 07-14-2008 04:09 PM
tuning peg for my ibanez gio GP13 Tech: Setup, Repairs and Mods 1 03-25-2008 11:52 PM
ok, wtf, Ibanez tuning problems AGAIN maliciousteve Tech: Setup, Repairs and Mods 6 12-15-2007 04:39 PM
korean locking nuts - loosin tuning does the hardware finish matters on tuning?? jlander Tech: Setup, Repairs and Mods 4 08-01-2006 08:43 PM
HTML code is On
