Hit a snag in my project and need some advise please - Jemsite
post #1 of 2 (permalink) Old 07-05-2008, 07:45 PM Thread Starter
Question Hit a snag in my project and need some advise please
Hey guys,
So i am working on a jem build and have a problem. When i bought my set of evolutions, i was under the impression that the neck i have took a 43mm nut. Turns out that 43mm is about 1mm too wide. Wouldnt worry me, but the neck and bridge evo's i got are F-spaced and from what i have read those are only for a 43mm nut or wider. Do i need to get regular sized pickups, or should the F-spaced ones line up with the strings well enough?
Thanks,
-Matt
vaifan5152 is offline
post #2 of 2 (permalink) Old 07-05-2008, 08:10 PM
Ayrton's Avatar
Re: Hit a snag in my project and need some advise please
The pickups you have will work just fine. You would never even notice 1 mm spread across a pickup.
Ayrton is offline
need advise drizzt75 All Other Guitars (including Prestige) 6 02-05-2008 06:00 PM
Need some advise perulv Tech: Setup, Repairs and Mods 5 10-07-2006 12:05 PM
need some p-up advise Dr.Z_EVO Pickups & wiring 12 06-30-2006 05:33 AM
Help! Advise me on an RG! Ironical Communion All Other Guitars (including Prestige) 5 02-10-2006 11:24 PM
Need some advise. PLEASE!!!! Scoff X Gear, Equipment, Recording & Off Topic 1 02-23-2003 05:27 PM
HTML code is On
