How to find these parts of JS1000 ??? - Jemsite
post #1 of 16 (permalink) Old 04-01-2003, 07:20 AM Thread Starter
Hi everybody,
i've just bought a used JS1000 BTB here in France, and would like to know where i can find a new whammy bar and also new sets of custom-stamped shims to raise the center saddle radius ...
Also have question about it : do you have pictures of your bridge saddles positions and height for me to compare?? Do you have thin metal shims on 6-E, 5-A, 4-D, 3-G, 2-B and 1-E strings??
For the moment i have only these shims on strings no 5,4,3 and 2.
Thanks for advices about it ...
mimi51 is offline
post #2 of 16 (permalink) Old 04-01-2003, 04:32 PM
You should be able to find a tremolo bar at any Ibanez dealer-they're a fairly common item. If not, you can try www.ibanezrules.com .
As for the shims...I'm fairly sure that the 1st and 6th string saddles are not supposed be shimmed. Part of the idea of shimming the saddles is to get the saddle profile to match the radius of the neck, which is curved. Thus, the high and low E saddles would need to be lower to meet that profile.
vaijem777 is offline
post #3 of 16 (permalink) Old 04-01-2003, 04:37 PM
The bridge radius is factory set and the shims are glued on. Saddle shims, for some reason, are no longer available anywhere.
Rich is online
post #4 of 16 (permalink) Old 04-01-2003, 04:50 PM
Automotive feeler gauge blades might work OK as shims if there are no other options.
JESTER700 is offline
post #5 of 16 (permalink) Old 04-01-2003, 04:53 PM
The variety of material you could use is endless. You can cut up nut shims, I used to cut up Pepsi cans long ago. The Custom Shop actually uses celophane tape to do micro shimming.
Rich is online
post #6 of 16 (permalink) Old 04-01-2003, 05:07 PM
I ordered some floyd designed shims from stew-mac as well. i dont know if they fit the edge though, they are cut to fit through the bolt holes as well.
sniperfrommars1 is offline
post #7 of 16 (permalink) Old 04-01-2003, 05:10 PM
Stew Mac no longer sells shims [at least what they told me when I tried to order]
Rich is online
post #8 of 16 (permalink) Old 04-01-2003, 06:04 PM
When i ordered "the tool" for intonation of ibanez edges through stew mac, they came with a pack of shims with the holes in them.....which was cool.
SilverSurfer2 is offline
post #9 of 16 (permalink) Old 04-01-2003, 06:15 PM
The Tool from StewMac is now discontinued.
post #10 of 16 (permalink) Old 04-01-2003, 06:20 PM
Gee, i hope mine don't break anytime soon.
They were expensive anyways
post #11 of 16 (permalink) Old 04-01-2003, 10:15 PM
They always gave you a little pack with the tool [but that was from the tool distributor], Stew Mac no longer has shims at all, nor does anybody else.
Rich is online
post #12 of 16 (permalink) Old 04-02-2003, 04:15 AM Thread Starter
Thanks for your answers first
And is it normal (because my tech was wondering why) that the low-E saddle is really lower than the others (also the high-E without shim)?
Is there a difference in height of the different saddles?
mimi51 is offline
post #13 of 16 (permalink) Old 04-02-2003, 09:17 AM
The whole purpose of the shims is to match the radius of the saddles with the radius of the fretboard....to achieve the lowest action possible when setting up the string height. That is why the high and low E strings are lower and without shims.....and this is normal because the radius of the fretboard.
post #14 of 16 (permalink) Old 04-02-2003, 12:58 PM
The low E *can* be quite low on some. Measure it and the A and shim to match.
Rich is online
post #15 of 16 (permalink) Old 04-06-2003, 11:42 AM Thread Starter
i 've got my JS back from my tech ... and i feel it's very high now ...
low E - 2.5 mm
hight e - 2 mm
I don't know what to do with it because i don't want to mess my JS trying to set it up lower than this.
I've never set up a floyd equipped guitar.
mimi51 is offline
bridge saddles , custom shop , equipped guitar , ibanez dealer , nut shim , string saddle , tremolo bar
Where can I find Ibanez 7 String parts? Weirdbeard All Other Guitars (including Prestige) 5 10-05-2011 11:50 PM
Ibanez jem project parts blow out (loads of parts) jsdisciple Classified Ads: Ibanez JEM/UV Guitars 9 08-17-2011 10:56 AM
help find parts please sanitarium All Other Guitars (including Prestige) 4 11-04-2008 06:41 AM
UV7 VWH Project guitar/parts: body, neck, pickups, parts… tobias. Classified Ads: Ibanez JEM/UV Guitars 5 08-23-2008 05:51 AM
where to find bridge parts for dt-350 x series? Brake All Other Guitars (including Prestige) 0 06-16-2004 11:39 PM
HTML code is On
