how high/low can cliplocks go on my jem? - Jemsite
post #1 of 14 (permalink) Old 12-11-2006, 07:43 PM Thread Starter
rya
well....
rya is offline
post #2 of 14 (permalink) Old 12-12-2006, 03:11 AM
Re: how high/low can cliplocks go on my jem?
not high enough. i had to get mine unstiched to make the strap shorter.
Dragon Slayer J is offline
post #3 of 14 (permalink) Old 12-12-2006, 03:12 AM
not too high, usually. the Cliplock is a pretty long strap by default, even if you set it as short as it can go. and they also make an extended version! if you're an under-chin player, the Cliplock is not for you, unless you have your mom cutting it, shorten it to your specs and stitch it back. which is a tricky job though, and you'll also have the plastic thing right onto your shoulder-bone (how you call it). if you're a belly-player then the Cliplock is the best hands down.
nuno is offline
post #4 of 14 (permalink) Old 12-12-2006, 04:30 AM
LMAO
P1: Hi, what instrument do you play?
P2: I'm a belly-player :-D
Jempy(HoTrOd) is offline
post #5 of 14 (permalink) Old 12-12-2006, 05:53 AM
Originally Posted by Jempy(HoTrOd) View Post
LMAO
Regards
André
fettouhi is offline
post #6 of 14 (permalink) Old 12-12-2006, 05:54 AM
must go higher
projectjem is offline
post #7 of 14 (permalink) Old 12-12-2006, 07:13 AM
Ayrton's Avatar
Tom likes them high...
Ayrton is offline
post #8 of 14 (permalink) Old 12-12-2006, 08:23 AM
Plastic thingy on my shoulder is the reason i quit straplocks...
Damn comfortable hung low tho
marianozz is offline
post #9 of 14 (permalink) Old 12-12-2006, 08:28 AM
I've just gotten a batch of straps from DiMarzio that are the "older/original" style as opposed to the longer tab ends that they've used for the last several years.
I had a talk with Petrucci a couple of years ago and he said they made shorter version for him.. so after I got my endorsement with them, I asked Steve Blucher and was told that they will make the "orginal length/shorter" strap for anyone. all you have to do is call them and order one.
BTW, its around 3 inches shorter than the current straps, doesn't sound like much, but made a HUGE difference in where the guitar sits.
JackButlerGOT is offline
post #10 of 14 (permalink) Old 12-12-2006, 10:44 AM
it'd be cool if they made it in pink, orange and yellow, too.
nuno is offline
post #11 of 14 (permalink) Old 12-12-2006, 02:48 PM
jim777's Avatar
Yeah, my old '80's cliplocks are much shorter, and really much better for that high prog guitar setup. The new ones are just a bit too long, so I use an old green strap for all my guitars and leave whatever clips are on them, on them. I have a bunch of the straps just sitting in cases unused
jim777 is offline
post #12 of 14 (permalink) Old 12-13-2006, 08:20 AM
I know they'll still do the green ones or any of the current colors in that link if you call.. the other option might be to take your old straps to a place that does car interiors/covering and have them shorten and re-sew for you. I believe the strap material is basically like seatbelt stuff and they'd have a machine that could easily do that. Just a thought.
post #13 of 14 (permalink) Old 12-13-2006, 08:31 AM
I always like my strap high as well. Makes for better picking in my case. It might look less HEAVY ROCK! but I'm not such a hard rocker anyhow.
Azrael is offline
post #14 of 14 (permalink) Old 12-13-2006, 01:58 PM
Wow, I was about to order my first ClipLock. I really like to play high like Morello and Steve Howe, so I contacted DiMarzio about ordering a shorter one.
waylay00 is offline
steve howe
Custom JEM vs Production JEM littlegreenman Ibanez JEM, UV, JS & Other Signature Models 46 06-17-2008 02:14 AM
An Old JEM for an Older Guy - Luv those vintage Jems David Ho Ibanez JEM, UV, JS & Other Signature Models 35 06-22-2005 11:29 AM
Got My New JEM 7VWH From Ibanez Rules Warrior Ibanez JEM, UV, JS & Other Signature Models 11 03-15-2005 01:06 PM
Nice story to tell - How I've found a JEM 10 jember Ibanez JEM, UV, JS & Other Signature Models 9 03-20-2002 05:22 PM
Cheapy new JEM switches - New vs Old JEM pickup selectors rikkbeatty Ibanez JEM, UV, JS & Other Signature Models 13 09-04-2001 12:51 PM
HTML code is On
