How are jem 20th bodies made? What are the swirls made of? - Jemsite
post #1 of 25 (permalink) Old 07-09-2011, 03:43 PM Thread Starter
Reviews: 11
Just wondering how the Jem 20th bodies are made.
Process, materials, etc.
Tried searching but found nothing...
Input appreciated
Bryancap77 is offline
post #2 of 25 (permalink) Old 07-09-2011, 04:56 PM
Re: How are jem 20th bodies made? What are the swirls made of?
I would think its acrylic slabs CNC'd to normal JEM specs, if i'm not mistaken. They would just use a different CNC bit, one meant for cutting plastic?
nato101010 is offline
post #3 of 25 (permalink) Old 07-09-2011, 05:23 PM
metalhead52's Avatar
I'm a machinist by trade for over 20 years. My best guess is it's CNC machined but will leave a dull finish on the cut surfaces. Then they would put it in an oven at a particular temp and "melt " the outside which would then turn all the surfaces clear. My best guess. I've machined acrylic before and that's what we did.
metalhead52 is offline
post #4 of 25 (permalink) Old 07-09-2011, 06:09 PM
Would they swirl it before they melted the outside? Or would they just swirl it after and clear coat it?
post #5 of 25 (permalink) Old 07-09-2011, 06:45 PM Thread Starter
Reviews: 11
It's not swirled in the normal fashion, there are like 3 separate sets of swirls going through the body. Its in the body, not on it like traditional swirls. That's why I was curious, because the way it looks gives me no idea on how it was made. I just got one yesterday, and im perplexed lol
post #6 of 25 (permalink) Old 07-09-2011, 06:53 PM
Reviews: 64
Maybe two parts of acrylic, the top one is mixed with that swirl.Swirl is inside of acrylic and not over it, I guess ....
6fingers is offline
post #7 of 25 (permalink) Old 07-09-2011, 07:18 PM
Reviews: 21
My bet is the body is laminated acrylic sheets, similar to level 1 bullet resistant glass. They probably lay down one sheet of acrylic, put down some swirl color, another thin sheet of acrylic, more swirl color and so on. They'd probably heat the laminate body section so that they would melt together. Then the body would be routed, sanded, polished with a torch, then final polished by hand. I doubt it's resincast as that would probably sound like crap.
mike570 is offline
post #8 of 25 (permalink) Old 07-09-2011, 07:19 PM
Reviews: 13
Uranium and plutonium......
-Wolfram
Wolfram is offline
post #9 of 25 (permalink) Old 07-09-2011, 11:08 PM
Reviews: 7
i'm sure Rich got something to say
SHAIBANEZ is offline
post #10 of 25 (permalink) Old 07-09-2011, 11:12 PM Thread Starter
Reviews: 11
Dude, I bet it would be SWEET to make a custom 20th, exactly the same as the first,(MINUS THE SWIRL) BUT Instead shooting it with like a small caliber gun a few times at different angles (if the body holds up)
That would be one badass finish.
post #11 of 25 (permalink) Old 07-10-2011, 12:17 AM
I have no idea how acrylic is worked. I figure at some point it has to be liquid though. My guess would be they were poured. It's the only way I can figure to keep any airpockets or bubbles out of it. Pour a layer, string on the veins, maybe they're even poured. Pour the second layer of clear, color, pour the third layer, let cool and CNC like it was anything else.
Only somebody that makes acrylic would really be qualified to answer though.
Rich is offline
post #12 of 25 (permalink) Old 07-10-2011, 06:19 AM
they melt it down and then someone is sick in the mixture then it dries.
philster_d is offline
post #13 of 25 (permalink) Old 07-10-2011, 10:35 AM Thread Starter
Reviews: 11
Richs theory is along the same lines as what I was thinking. The swirls have got poured on each of the parts while the body is still semi melted, because the swirl veins aren't just paper thin lines, they actually are swirled about an inch in diameter on each layer. It's gotta be a strenous process
post #14 of 25 (permalink) Old 07-10-2011, 12:42 PM
Reviews: 12
Red face Re: How are jem 20th bodies made? What are the swirls made of?
The acrylic was forced to endure long periods of time exposed to old Vai/Roth videos during a Clockwork Orange type of process! Afterward, of course the acrylic changed into a swirled combination of Vai rock star goodness...Then they just go ahead and machine it like normal!
http://www.youtube.com/watch?v=PP12su7JooM
http://www.youtube.com/watch?v=35JYM...eature=related
http://www.youtube.com/watch?v=I4qh_...eature=related
If you watch all of these in a row, you'll actually start to swirl from the inside! It's amazing...
DEADTUNES666 is offline
post #15 of 25 (permalink) Old 07-10-2011, 01:07 PM
It's probably molded and the color veins are shot through it while it's still liquid.
Takin' a Ride is offline
20th , anniversary , ibanez jem
made in japan jackson imports vs made in korea ibanez RG's VOLTAGE All Other Guitars (including Prestige) 50 12-11-2009 03:45 PM
This just MADE my day! SonicProvocateur Off-topic / Miscellaneous 6 12-04-2009 09:05 AM
suggestions for my to-be-made custom made 7 string guitar? ninelives1980 All Other Guitars (including Prestige) 7 05-06-2005 02:48 PM
who was the fellow who made custom RG bodies??!? gemini8026 All Other Guitars (including Prestige) 2 06-24-2004 10:59 AM
RG7321 made in Japan? - i thought these were korean made? reguv760 All Other Guitars (including Prestige) 2 12-13-2001 07:54 AM
HTML code is On
