How to recognize original JEM Pickups - Jemsite
post #1 of 6 (permalink) Old 05-14-2014, 03:35 AM Thread Starter
Hi all,
maybe a stupid question but how can you make sure you have the right, original PUs in your JEM ?
I do ask you since I am offered a 777sk but looking at the PUs I have my doubts. First of all they don't feature that sort of bleach we all know ( although I must say the body hasn't faded much, too). Second, if you look at the original photos from Ibanez you see that the early ones feature three tiny holes on the humbucker pairs on bridge and neck (hole positions mirrored), while on that guitar there are only two holes per PU.
Confusing enough you can see a lot of 777sk with that same 2 hole setup on Jemsite and for sure they are no fakes.
So can anyone shed a light on what the storyline is here?
Thx
Dh88
diehard1988 is offline
post #2 of 6 (permalink) Old 05-14-2014, 07:40 AM
Re: How to recognize original JEM Pickups
It depends on when it was made. The change in the pickup covers happened at some point in 1988. I've had two '88 SK's and one had the pickups with three holes and one had pickups with two holes. All '87 guitars should have three holes and all '89 guitars should have two holes.
Aside from that, the plastic should be very opaque and should probably have a soft pink color. Newer pink pickups are slightly translucent and are much redder.
Takin' a Ride is offline
post #3 of 6 (permalink) Old 05-14-2014, 10:28 AM
NSR
The two-hole pickups that you describe do indeed appear to have been introduced in '88, as they're on my '88 VDY and every other VDY I've seen. They also appear to have an orange hue rather than the deep or faded pink that are usually seen on models with the three-holes. They're sometimes on SK's and VSK's although personally I've seen more '89 models of the SK's and VSK's with the three-hole variants.
NSR is offline
post #4 of 6 (permalink) Old 05-14-2014, 03:00 PM Thread Starter
Interesting to say the least...point being that given the serial number of the 777 I got offered it is presumably built in '87 and it features the two-hole type. Now the screws holding the humbuckers are not black so it would be fair to assume the original humbuckers were replaced. Nevertheless they seem to be correct types....confused...Any other idea how to confirm those PU being genuine?
post #5 of 6 (permalink) Old 05-14-2014, 04:17 PM
Early '87 are non f-spaced.
Original pups does have golden baseplates.
morien is offline
post #6 of 6 (permalink) Old 05-14-2014, 05:00 PM Thread Starter
thanks for hinting the golden baseplates...definitely a good one...
777 , jem , jem 777 sk
Do you recognize this guitar ? eemeli All Other Guitars (including Prestige) 5 10-25-2013 07:59 AM
Does anyone recognize this humbucker? Fastmerc Pickups & wiring 4 09-23-2012 07:13 PM
Anybody recognize this Charvel? shyguy1987 All Other Guitars (including Prestige) 16 06-16-2008 06:48 PM
how to recognize a JS1???? nico86 Ibanez JEM, UV, JS & Other Signature Models 14 04-08-2008 08:40 AM
Do you recognize this Ibanez? DirtyBird31 All Other Guitars (including Prestige) 2 09-16-2003 12:08 AM
HTML code is On
