I have a screw loose! - LO Pro Edge problem. - Jemsite
post #1 of 3 (permalink) Old 03-13-2001, 04:18 PM Thread Starter
Reviews: 5
I was reading a post a couple days ago about how a lot of dealers never tighten the stud screw before setting up JEMs and so I decide to check my JEM7VWH. *I use the 1.5 mm allen wrench and locate the bass side screw, but can not find one on the treble side. *Is it possible that it fell out and now I need a new stud screw for my post? *If so where do I get one?
jem7vwh is offline
post #2 of 3 (permalink) Old 03-13-2001, 05:03 PM
I found mine loose too… after a kind person informed me of their existence. These screws are hidden from view, therefore hidden from do-it-yourself armatures like me and even from some pros. Ibanez friendly techs are valuable. It is an oversight that can lead to bigger problems… like oblong holes. (ya’ know, those little bushing thingies in the body that the posts screw into)
Told you I was an armature.
NOTE: I first learned of these setscrews in the Jemsite Tech section, but forgot about them. Almost a big mistake. Luckily someone reminded me. Now I am hip and happy.
bob oakman is offline
post #3 of 3 (permalink) Old 03-13-2001, 08:23 PM
One way to find out......remove the trem and take the trem post out and look :biggrin:
It's probably still there...but realllllllllllllly loose.
J>
Vaibanez is offline
allen wrench
One heck of a neck-screw problem Ke^in All Other Guitars (including Prestige) 13 08-02-2013 08:59 AM
Truss rod screw loose and still not enough bow Silverburst Tech: Setup, Repairs and Mods 5 01-30-2010 01:26 PM
Edge posts w/ set screw. Will they fit in an Edge III hole? Stygian Tech: Setup, Repairs and Mods 1 06-23-2008 05:57 PM
need help with S470 ZR Trem - loose screw Hairp1ck All Other Guitars (including Prestige) 1 07-20-2006 10:38 AM
Stud set screw problem MichalD Tech: Setup, Repairs and Mods 2 07-25-2003 09:56 AM
HTML code is On
