Ibanez Edge Pro 2 help - Jemsite
post #1 of 5 (permalink) Old 10-01-2014, 02:13 PM Thread Starter
Hi Guys,
I'm trying to get a new body to replace the one on my damaged Jem 555 which is fitted with and edge pro 2 bridge.
does any one know if there's a routing difference between the edge 2 and a regular edge??
Thanks!
Jaym183 is offline
post #2 of 5 (permalink) Old 10-01-2014, 04:34 PM
RGTFanatic's Avatar
Re: Ibanez Edge Pro 2 help
Yes Jayman- the routes for the Edge and Edge Pro II are different. You'll have to get a body that is routed for the Edge Pro or Edge Pro II.
RGTFanatic is offline
post #3 of 5 (permalink) Old 10-01-2014, 05:08 PM Thread Starter
Thanks!
so a body that's routed for an edge pro will work??
also, do you know which part requires to routed differently??
Many thanks for the help!
Jaym183 is offline
post #4 of 5 (permalink) Old 10-01-2014, 05:12 PM
RGTFanatic's Avatar
Originally Posted by Jaym183 View Post
Thanks!
Yes, an Edge Pro body will work without modification.
The area that's cutout for the trem block will have to be routed bigger to accommodate the Edge/Lo-pro block. You will also have to open the top of the route slightly for the "wings" of the ED/LP to fit. You will also need to get new Studs and anchors for an EP/LP routed body. The studs and inserts for the EP/EPII are too small to fit snugly into the EP/LP holes.
BTW.... welcome to Jemsite Jaym!!!
post #5 of 5 (permalink) Old 10-01-2014, 05:23 PM Thread Starter
I see!!
Massive thanks for the help!
And thanks again, have to say I like it here
Could I possibly send you a link to a body I've seen and tell me if it would sutible?
Jaym183 is offline
edge pro 2 help , ibanez jem 555
LF: Ibanez Edge or Lo Pro Edge bridge in Cosmo Black supergirl20_06 Classified Ads: Guitars and Gear 0 09-19-2010 10:02 AM
FT Ibanez Edge Pro Powder Cosmo Black for Edge Pro Gold supergirl20_06 Classified Ads: Guitars and Gear 2 12-02-2009 10:05 AM
FT Ibanez Edge Powder Cosmo Black for Edge Pro Gold supergirl20_06 Classified Ads: Guitars and Gear 1 06-26-2009 04:45 PM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 08:16 PM
My beef with Ibanez's Edge & Lo-Pro Edge tremolos. cyberman Comments to Ibanez 2 01-06-2003 11:46 PM
HTML code is On
