identifying year of Edge? - Jemsite
post #1 of 25 (permalink) Old 10-02-2007, 08:11 AM Thread Starter
I'm wondering if there is anyway to identify what year an edge or edge lo-pro is from? Is there even anything to distinguise reissues from origionals? thanks
Devon8822 is offline
post #2 of 25 (permalink) Old 10-02-2007, 10:42 AM
jb4674's Avatar
Reviews: 18
Re: identifying year of Edge?
I don't think there would be a way, since the trems are not stamped with a serial number that I know of. I could be mistaken though... Rich might be able to have a better answer.
Jimmy
jb4674 is offline
post #3 of 25 (permalink) Old 10-02-2007, 12:02 PM
When did Ibanez stop putting the palmguard (or whatever it is) on the JEMs? I always thought that it added a unique look to those old 777s...
bringer of torture is offline
post #4 of 25 (permalink) Old 10-02-2007, 12:20 PM
Rodney James is offline
post #5 of 25 (permalink) Old 10-02-2007, 12:37 PM
there are a few details that can't detect the exact incept date but pretty much the period, early '86/'87, the '90s and so on.
for example, the first Edges in '86/'87 had a different spring block, it was thinner but wider and taller, it was called S or HS. see pic:
it also had the arm insert with a longer threat, vs the '90s Edge where the threat was cut shorter:
early Edge arm insert:
(yeah, it's a Lo-Pro but no matter)
'90 Edge arm insert
also, the early Edge had no Stud-Locks. hope that helps
nuno is offline
post #6 of 25 (permalink) Old 10-02-2007, 12:52 PM Thread Starter
Some good info, what I want to find out is if, some bridges i have my eye on, are reissues from the late ninties or later or if there are from the early 90s. I'm restoring the bridge on a jem so im looking for a 90' one.
post #7 of 25 (permalink) Old 10-02-2007, 01:39 PM
hmmmm good question i would guess late 40's
projectjem is offline
post #8 of 25 (permalink) Old 10-02-2007, 01:44 PM
^^ I had to think about that for a minute
It's been a long day
andy7jem is offline
post #9 of 25 (permalink) Old 10-02-2007, 04:15 PM
Yeah I was thinking ,,A Les Paul doesn't have a trem, what's that about?'' But then I got it...
Reinder is offline
post #10 of 25 (permalink) Old 10-03-2007, 04:52 AM
i think the only "reissue" of the Edge has been made for the RG 20th. other than that, an Edge is just an Edge. the only detail i'd be aware of is the taller spring block from early '86/'87, which would stick out of the trem cavity.
nuno is offline
post #11 of 25 (permalink) Old 10-03-2007, 05:03 AM
another couple of details that just came to mind: the early Edges were molded smoother, the saddles edges were rounder, smoother. since around mid '90s they were molded squarer and tighter. also, early Edges didn't have the Fine Tuners lock plastic rings.
nuno is offline
post #12 of 25 (permalink) Old 10-03-2007, 08:40 AM
post #13 of 25 (permalink) Old 10-03-2007, 08:52 AM Thread Starter
Originally Posted by Pirvey Chinnfield View Post
Actually the edge took a change from the early years to mid 90's somewhere. We compared a 1998 RG550DY to 1987 88 & 89 Jems, and the 98 trem is different, base plate and spring plate.
So what exactly is the difference between the baseplate and spring plate over the older and earlier models?
post #14 of 25 (permalink) Old 10-04-2007, 03:23 AM
I'm not sure of the exact difference but I don't think it will be a difference that would affect its performance/originality in a 90's Jem anymore than not using every original screw that was supplied.
Sunrise is offline
post #15 of 25 (permalink) Old 10-04-2007, 08:51 AM
arm holder , base plate , edge trem , edge trems , les paul
edge pro to lo pro rya Ibanez JEM, UV, JS & Other Signature Models 54 11-11-2012 03:24 PM
edge 3 to lo pro edge hoockey All Other Guitars (including Prestige) 16 11-22-2006 04:15 AM
Can I use Edge posts with an Edge Pro?? PatrickSimsCustomShopUSA Tech: Setup, Repairs and Mods 8 10-26-2006 10:00 AM
String spacing of Edge/Lo-Pro vs Edge Pro MetalZone All Other Guitars (including Prestige) 21 10-24-2006 07:59 AM
Edge III Mystery... Solved? eclecticmage Tech: Setup, Repairs and Mods 47 10-22-2006 12:08 PM
HTML code is On
