JS-1000 Lo Pro Edge - Shims under saddles?? - Jemsite
post #1 of 7 (permalink) Old 05-08-2001, 05:34 PM Thread Starter
I just noticed that there were metal shims sticking under the sadles of my lo-pro, thus raising them. Is this normal? I just checked the classic Edge that I've got, and I don't see them there....
Is this because of that radius "copy from satch own" neck thinggy?
Thanks.
Jeroenn is offline
post #2 of 7 (permalink) Old 05-08-2001, 05:38 PM
JS-1000 Lo Pro Edge
I take it the Edge isn't on a JS. Shims are supposed to be under the center 4 saddles to correctly radius the bridge to the fretboard.
Rich is offline
post #3 of 7 (permalink) Old 05-08-2001, 06:11 PM Thread Starter
JS-1000 Lo Pro Edge
Well, as a matter of fact, the Edge now is on the JS. No strings on it yet, though.... So I need to move the shims to the Edge also, I suppose?
There is a lot of setting up to do on this one, it also has shims under the toplock, two layers.
(the reason I switched the trems, is because the Pro has some armholder troubles I need to get fixed).
They're basicly the same, so I don't mind it for now..
Jeroenn is offline
post #4 of 7 (permalink) Old 05-08-2001, 06:14 PM
JS-1000 Lo Pro Edge
The shims are stuck on with double side adhesive tape, have fun! Better to just cut up nut shims for the Edge, that's what I do. You need 1 medium and 1 thick.
Rich is offline
post #5 of 7 (permalink) Old 05-08-2001, 06:17 PM Thread Starter
JS-1000 Lo Pro Edge
So I just found out.... (Yuck)...
Thanks for the info!!
Jeroenn is offline
post #6 of 7 (permalink) Old 05-08-2001, 08:04 PM
JS-1000 Lo Pro Edge
I've "transfered" satch shims before and the gummi tape helps to reposition them on the next bridge. Just as long as you remember that the shimmed bridge goes with the satch neck, regardless of which neck the guitar is on. Sort of an elementary point, but I didn't see it mentioned.
frankfalbo is offline
post #7 of 7 (permalink) Old 05-11-2001, 06:06 PM Thread Starter
JS-1000 Lo Pro Edge
Got that figgured out, but thanks...
But I've fixed the Pro Edge. The armholder got real loose. So that one went back on the JS.
Now I need to set it up completly again. I can't get the action low. It's 2 mm now, and if I go lower, the buzzing would be to much.
Jeroenn is offline
nut shim , pro edge
How to reglue saddle shims on an Edge Zero... Blacksabba Tech: Setup, Repairs and Mods 18 10-17-2014 04:39 PM
Shims on Original Edge trem? maqify Ibanez JEM, UV, JS & Other Signature Models 1 11-06-2012 10:19 PM
Shims for trem saddles? AxeHappy Tech: Setup, Repairs and Mods 5 12-19-2008 01:51 PM
shims under floydrose saddles? marino Tech: Setup, Repairs and Mods 6 12-28-2006 06:06 PM
Looking for Edge tremolo saddle shims Econ Classified Ads: Guitars and Gear 0 12-14-2005 06:13 PM
HTML code is On
