JS 1000 - String Breakages- Help! - Jemsite
post #1 of 10 (permalink) Old 03-28-2002, 03:04 PM Thread Starter
I recently purchased a JS 1000 TB - really happy with the guitar - looks/sounds/feels great! - except for one minor (i hope it's minor) snag! The godamm high E snaps all the time! Which is a complete nightmare at gigs as you can imagine! - The string breaks the exact same place - at the saddle leaving a few mm of string in the saddle - so I swapped the saddle around with the B's saddle (which never breaks) and still no change! I'm using 9's - Roto's or D'adds mostly -
Had anyone any ideas on whats causing this!?I've even tried laying of on the high E a bit - but it breaks sometimes just strumming a chord - yet the most strenueous pain inducing face crumpling bend minght do no damage (and visa versa) Sorry if there's a thread on a similar topic - I could'nt find one
Any tips/advice opinions greatly appreciated!
Viable is offline
post #2 of 10 (permalink) Old 03-30-2002, 08:14 AM Thread Starter
anyone?!
Viable is offline
post #3 of 10 (permalink) Old 03-31-2002, 06:40 AM
:loco: take it to your repair shop, It wll be easier
sparrow is offline
post #4 of 10 (permalink) Old 03-31-2002, 07:11 AM
Super Moderator
jono's Avatar
It sounds like you have a sharp edge on the saddle of the e string on the trem. Try a set of saddle singers... savers... sausages?!!? ?!?! or something like that.. little protective inserts for the trem. Failing that take it to your local repair guy and see if he can smotth the saddle for you.
jono is offline
post #5 of 10 (permalink) Old 03-31-2002, 01:43 PM
Make sure the trem angle is correct or else you're putting alot of extra tension on the spot the string bends coming off the saddle.
Rich is offline
post #6 of 10 (permalink) Old 03-31-2002, 04:06 PM
Rich on 1:43 pm on Mar. 31, 2002
but then, why would the E break? Isn't the G string considered the weakest?
yurich is offline
post #7 of 10 (permalink) Old 03-31-2002, 06:33 PM
And why would a thicker string be weaker?!
Rich is offline
post #8 of 10 (permalink) Old 03-31-2002, 07:59 PM
honestly, I don't know I just heard it somewhere. plus, I noticed it goes outta tune the most of all strings
yurich is offline
post #9 of 10 (permalink) Old 03-31-2002, 09:10 PM
snakepit on 7:59 pm on Mar. 31, 2002
Obviously you're not stretching your strings in enough.
Rich is offline
post #10 of 10 (permalink) Old 04-05-2002, 02:17 PM Thread Starter
trem angle is pretty perfect - it does seem like the saddle is the problem - but as I said I *swapped saddles with the B and it (which never breaks) and it STILL does - guess maybe it's the 9 goes rather than the 11
Viable is offline
String Breakages Pooluke41 Tech: Setup, Repairs and Mods 3 12-27-2010 09:47 PM
js 1000 and js 1000"js custom"..... nico86 Ibanez JEM, UV, JS & Other Signature Models 3 04-10-2008 02:02 AM
JS 1 vs. JS 1000 - What's the dif? JS Clone 2 Ibanez JEM, UV, JS & Other Signature Models 33 04-27-2004 02:50 PM
7-String Tune-O-Matic? 7-String String Saver Saddles? Drache713 All Other Guitars (including Prestige) 1 12-03-2002 11:27 PM
js 900 / js 1000 sam669 Ibanez JEM, UV, JS & Other Signature Models 7 10-15-2002 12:00 PM
HTML code is On
