Js 3 way toggle vs. Lespaul toggle - can you get the same re - Jemsite
post #1 of 4 (permalink) Old 11-26-2001, 06:42 PM Thread Starter
does anyone knowledgeable in guitar electronics know if you can use a les paul "leaf" 3 way toggle to get the same pickup selections/results as you would with the JS 3 way toggle?? I ordered the les paul 3 way from stew mac, and i noticed they look different than the Js 3 way. The Js toggle is a brown box with 3 prongs, and the stewmac lespaul doesnt have the box/prongs. Is there really any differences, advantages between the two kinds?? Can i get the same exact pickup selections with the stewmac 3 way switch??
SilverSurfer2 is offline
post #2 of 4 (permalink) Old 11-27-2001, 10:17 AM
The two switches do the same thing. *As long as it physically fits inside the guitar, you shouldn't have any problems.
kuma is offline
post #3 of 4 (permalink) Old 11-29-2001, 06:13 PM Thread Starter
Kuma, do you know how to wire dimarzio's to the "leaf" type 3way toggle from stew mac?? I've never used the stewmac toggle switches.
Does anyone know how to wire the Paf pro/FRED's to the stewmac toggles?
post #4 of 4 (permalink) Old 12-01-2001, 09:27 AM
You wire it the same way as the JS switch. *There is a prong on each side of the switch, you attacth the hot wire from the pickups to these, one on one side and one on the other. *There's also a prong coming out the back of the switch. * Attach that to ground (it's the same as the center prong on the JS switch.)
If you don't already have it, you can get the schematic for the JS off the Ibanez website. *Just substitute your toggle with the one they have pictured.
kuma is offline
les paul , paf pro , pickup selection , toggle switch
Toggle switching. PatrickL101 All Other Guitars (including Prestige) 7 07-19-2008 09:09 PM
wiring v7/v8 with 3 way toggle switch nutbehindthewheel Pickups & wiring 1 02-27-2008 09:55 PM
Toggle switchable volume cut? jm1681 Tech: Setup, Repairs and Mods 15 12-14-2006 03:04 PM
Will mini toggle fit in pot's hole? toneboy Pickups & wiring 12 05-24-2006 08:46 PM
3-way toggle switch on JPM100 Ibanezuv777 Tech: Setup, Repairs and Mods 1 04-21-2005 01:28 PM
HTML code is On
