JS neck pickup replacement (spacing) - Jemsite
post #1 of 7 (permalink) Old 04-03-2004, 03:15 PM Thread Starter
Hi,
I have a question regarding replacing the pickup on the neck position of a JS1000. should the replacement be F-spaced as well? does anyone know about this? the dimarzio website says that F-spaced pickups can be used in the neck position when the nut width is greater than 43mm. but the JS has a nut width of 42mm. but it seems that a stock JS comes with a F-spaced pickup in the neck position....
any ideas, anyone??
thank!
chemicalmagical is offline
post #2 of 7 (permalink) Old 04-03-2004, 04:46 PM
For what its worth, both F-Spaced and regular can be used at the neck
Rob
Jem7RB MK is offline
post #3 of 7 (permalink) Old 04-04-2004, 09:23 AM
yup, they can... but there are no f-spaced neck humbuckers...
they do only f-space them for the bridge position.
doesn't matter at the neck, really.
or did i get something wrong there again?
saTa is offline
post #4 of 7 (permalink) Old 04-04-2004, 12:59 PM Thread Starter
hmmm.... actually dimarzio makes all full-size humbuckers available with the f-spacing option. so I'm still trying to figure out which is the right one to fit the JS...
thanks for your input guys!
post #5 of 7 (permalink) Old 04-04-2004, 01:13 PM
For neck pickups, f-spacing isn't an option.
Two hands31 is offline
post #6 of 7 (permalink) Old 04-09-2004, 11:00 PM
No, he's right, you can get *ANY* full size Dimarzio humbucker in F-spaced. Including neck models. In fact, Dimarzio recommends using an F-spaced pickup in the neck if you have a 1 11/16(43mm) or wider nut.
toshiro is offline
post #7 of 7 (permalink) Old 05-16-2004, 04:01 PM
PAF Joe is a neck pickup & is available "F" spaced. Just installed one in a customer's strat. It's not really necessary though.
Dr_Guitar is offline
bridge position , neck humbucker , neck pickup , neck pickups , neck position , paf joe , spaced pickup
pickup spacing sirshredsalot All Other Guitars (including Prestige) 4 09-01-2009 09:49 PM
Pole Spacing - Difference between F-spacing and ordinary spacing on dimarzion evo's corkyo4 Pickups & wiring 1 04-09-2007 07:36 AM
Pickup spacing... nayabisoba All Other Guitars (including Prestige) 1 04-14-2006 09:17 AM
pickup spacing Robot Boy All Other Guitars (including Prestige) 1 10-28-2005 02:04 PM
Replacement for Universe neck pickup ernieball Ibanez JEM, UV, JS & Other Signature Models 6 10-18-2004 12:28 PM
HTML code is On
