Jem 555 edge pro questions - Jemsite
post #1 of 4 (permalink) Old 09-29-2016, 04:41 PM Thread Starter
I'm haveing trouble levelling my edge pro 2 on my 555. I don't think there is enough space in the back cavity as I cant pull the guitar trem level, it just hits the back.
I'll leave a link to some photos. Hopefully someone can figure out this issue and as i'm starting to think I have a fake jem.
darkcola44 is offline
post #2 of 4 (permalink) Old 09-29-2016, 04:50 PM Thread Starter
post #3 of 4 (permalink) Old 09-29-2016, 07:10 PM
Re: Jem 555 edge pro questions
What gauge of strings and tuning are you using? Do you have the neck shimmed at all? How long have you had this instrument. At a quick glance it looks like a real 555 to me. From the looks of it you have 4 springs installed, whats the reason behind this? The typical number is 3. If you are in standard tuning and you have 9 gauge strings you can start by tightening the spring claw screws in the back of the guitar. But honestly you should probably go through rich'es full setup guide anyways. http://www.ibanezrules.com/tech/setup/index.htm
sniperfrommars1 is offline
post #4 of 4 (permalink) Old 10-01-2016, 08:44 AM
Obviously when you're pulling the trem up sustain block rests against the cavity wood that does not let the trem go further. Maybe you have your trem knives totally worn out? Are the trem posts okay ?
klee is offline
edge pro , jem 555 , questions
Can I swap in an edge pro, or pro II bridge for a lo-trs on Jem 555? robsjem Tech: Setup, Repairs and Mods 5 09-10-2012 11:53 PM
Jem 555 with Edge Pro II Petie All Other Guitars (including Prestige) 22 07-28-2003 04:47 PM
jem 555 and edge pro 2 robert hayes All Other Guitars (including Prestige) 1 06-13-2003 12:49 PM
Lo-Pro edge on JEM 555? Greenie Tech: Setup, Repairs and Mods 2 02-24-2003 12:19 PM
HTML code is On
