JEM 555 Quality - quality issues with the jem 555 - Jemsite
post #1 of 4 (permalink) Old 07-24-2001, 07:45 PM Thread Starter
Hello, i was just wondering if i could get a jem555 with a case at $400, and then put an low profile edge tremolo system in there, is that a better deal that spending about the same amount on a rg550 or 570, just comparing the 555 with lo pro edge to other non jem/uv ibanez models how does it compare, is it a guitar worthy of the ibanez name?
kylemac is offline
post #2 of 4 (permalink) Old 07-24-2001, 09:46 PM
Reviews: 5
JEM 555 Quality
in order your answers, sir.
1. *Even at $400, the cost of outfitting a LoPro edge and refinishing would put you right at the cost of a used JEM.
2. *No, I would say it would be better to start off with a used RG-570 or better or a used JEM777, JEM77, or JEM7 model.
3. *Compared to other Ibanez models the 555 is significantly less valuable. *It was made in a Korean factory by lower-paid laborers and is more likely to have electronics issues. *The bodies are generally made of less acceptable woods. *The fretboard inlay is an unattractive half vine/half dot format. *And as you noted the bridge is completely inferior. *If we were to compare JEMs to a motor line, the JEM is Chevrolet's Corvette and the 555 is a Prism.
jem7vwh is offline
post #3 of 4 (permalink) Old 07-24-2001, 10:59 PM
JEM 555 Quality
I agree. Getting a 570 is a better buy. A Jem 7xx is better, but will cost quite a bit more.
Rick
rickboot is offline
post #4 of 4 (permalink) Old 07-26-2001, 01:13 AM
site founder 0% owner
jemsite's Avatar
JEM 555 Quality
This has been widely discussed. the LoPro is NOT a direct swap. See FAQ/Links for more info, as well as archived topics in the forum... glen
jemsite is offline
Closed Thread
edge trem , edge tremolo system , ibanez models , pro edge , tremolo system
RG1527Z Quality issues komentaja All Other Guitars (including Prestige) 10 06-28-2012 05:51 AM
Anyone know the quality? Coatescolt Gear, Equipment, Recording & Off Topic 5 12-20-2009 03:13 PM
Jackson Quality "Levels" vs Ibanez Quality "Levels" Big Red All Other Guitars (including Prestige) 104 09-27-2008 02:30 PM
Jem Quality Silktone Ibanez JEM, UV, JS & Other Signature Models 8 09-30-2003 10:39 AM
Are ALL Lo-Pro's the same quality? Contra Tech: Setup, Repairs and Mods 1 09-17-2002 08:11 AM
HTML code is On
