JEM 6-str Tremolo Block fits on 7-str Trem? - Jemsite
post #1 of 2 (permalink) Old 05-03-2008, 06:22 AM Thread Starter
Question JEM 6-str Tremolo Block fits on 7-str Trem?
Are the TREMOLO BLOCKS on the 6-string JEM Edge (or Lo-Pro) tremolos interchangeable with the UV 7-string tremolos?
Do they have the same center distance of the outer screw holes?
Did they have 31mm Tremolo Blocks on the original FP77 Edge trems, or what?
Metallion is offline
post #2 of 2 (permalink) Old 05-03-2008, 11:28 AM
Re: JEM 6-str Tremolo Block fits on 7-str Trem?
All Edge or Lo Pro blocks are swappable between 6 and 7 string trems.
Occasionally you will find some odd length [wrong] blocks on some of the 6 string trems.
Rich is offline
edge trem , edge trems
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 10:57 AM
Jem 555 broke trem nut:( HELP! eatsleepplayguitar Tech: Setup, Repairs and Mods 8 10-16-2006 11:24 AM
FP Trem Weirdness? - Black Block iain Ibanez JEM, UV, JS & Other Signature Models 6 10-30-2001 02:07 PM
Quick Tuning on Lo Pro Edge 7 - Trem Block Question rlintz All Other Guitars (including Prestige) 5 08-12-2001 02:45 PM
Jem 7VW *Setting up trem to go up - Jem set up toneseeker Ibanez JEM, UV, JS & Other Signature Models 1 12-22-2000 12:23 PM
HTML code is On
