Jem 70v edge bridge question - Jemsite
 1Likes
  • 1 Post By nullicle
post #1 of 4 (permalink) Old 09-28-2017, 09:14 AM Thread Starter
Hi guys,
I have this guitar and noticed when I completely took the strings off a while ago that the bridge looked quite weird (to me). Please see the below youtube video using its ID (sorry I couldn't post a link this is my first post, if you google this it will come up)
JtUMWPScrw8
I'm not sure if this is how it is supposed to be or if something has happened. You don't notice it when playing as the tension moves it out of that position.
Any feedback would be much appreciated!
Cheers,
Chris
nullicle is offline
post #2 of 4 (permalink) Old 09-28-2017, 09:17 AM
Re: Jem 70v edge bridge question
peromucho7 is offline
post #3 of 4 (permalink) Old 09-28-2017, 09:21 AM
Everything seems fine.
Springs are pulling tremolo their way and there is no strings tension to balance bridge.
When changing strings change one at time , not all strings at once until you learn how it is working.
But when you take all strings out you can lube it with chapstick or similar.
post #4 of 4 (permalink) Old 09-28-2017, 09:46 AM Thread Starter
Hi there,
thanks for that, gives me some piece of mind. I usually change one string at a time, but I moved country and took strings off before hand. Not leaving this beauty behind!
peromucho7 likes this.
nullicle is offline
bridge , edge tremollo , ibanez , steve vai
RG 550 RFR Edge Bridge question Atomant Tech: Setup, Repairs and Mods 5 09-22-2015 11:21 AM
WTT: my Gold Schaller FR bridge for your Black Lo Pro Edge or Edge bridge supergirl20_06 Classified Ads: Guitars and Gear 2 08-05-2011 05:57 AM
Quick question - can i fit the edge bridge on a new JS1000? lonewolf Ibanez JEM, UV, JS & Other Signature Models 2 12-04-2008 11:09 AM
Bridge Knife Edge Question tt0511 Ibanez JEM, UV, JS & Other Signature Models 5 05-04-2007 11:24 PM
Question about the edge pro bridge on higher end Ibanez elpingua All Other Guitars (including Prestige) 3 11-19-2005 09:20 AM
HTML code is On
