Jem 777 fretboard separation from neck - Need help to repair - Jemsite
post #1 of 6 (permalink) Old 08-26-2001, 11:10 PM Thread Starter
Hey Guys! *I'm having a problem with my LNG. *The neck has a crack between the fretboard and the neck, starting at the nut and ending at about frets 2-3, where it looks like the fretboard has separated from the neck. *Has anyone else seen this? *A tiny crack had been there since I bought it on E(vil)Bay last Dec., but while I had the neck off today to clean and shim it ala Rich's "Grunge Off", the crack got bigger, and now I've got bad buzzing all over frets 1-5. *Truss rod adjusting won't help, because the fretboard is sticking up too high! *I guess I could try clamping it down and gluing it. *Any suggestions would be appreciated!
hendjo1 is offline
post #2 of 6 (permalink) Old 08-26-2001, 11:19 PM
You'll need some good wood glue, a clamp, wet paper towel, clear mylar like a report cover, and a spreader (I have a small wedge that's sorta like a pencil but with a tip as wide as it is around). *Spread the board from the neck enough to allow you to get glue in there. Cut the mylar into a strip. I'll lay glue all down the seperation and then on the mylar, work the glue into the gap as deep and far as you can using the mylar (if you use paper it'll just act like wet paper, it needs to be stiff and why I use the mylar). When you get the glue dispersed clamp the board down, but not TOO tight, you don't want to squeeze all the glue out!! Just clamp it down till it visually looks together, no further. Cleanup all the glue that came out with the wet towel and let it sit overnight. Problem solved, and a very easy fix, I'd rate it a 1 hammer on the toughness scale :biggrin:
Rich is offline
post #3 of 6 (permalink) Old 08-26-2001, 11:27 PM
I should have mentioned, remove the nut, when you spread the board you want to do it from the end where the nut sits so you won't visibly marr the wood anywhere else.
Rich is offline
post #4 of 6 (permalink) Old 08-28-2001, 12:49 AM
Also, use two pieces of wood (front and back) with the clamp. *Insert them between the clamp and the wood of the neck.
There's nothing worse than un-doing the clamp and seeing a nice little circle on the back of your neck. *:-)
"one hammer"...that's frickin' funny!
Kevan is offline
post #5 of 6 (permalink) Old 08-28-2001, 12:58 AM
Worng type clamp I use the mini pistol grip clamps that have very soft rubber feet. 1st page of the Used Guitar Primer on my site shows the large version I also use.
Rich is offline
post #6 of 6 (permalink) Old 08-28-2001, 11:54 AM Thread Starter
Thanks for the tips guys! *LNG neck is clamped and glued as I type. *I'll let you know how it turns out.
Now if If you'll excuse me, I need to get some rehab for this Ibacrack problem! :mc: *
hendjo1 is offline
truss rod
Fretboard busted how to repair? addictedtojane Tech: Setup, Repairs and Mods 1 09-20-2011 07:31 PM
Neck repair help (bass) Speedabob Tech: Setup, Repairs and Mods 31 08-08-2011 01:46 PM
Wizard neck repair. metalhead52 All Other Guitars (including Prestige) 4 12-27-2010 07:07 AM
My fretboard is lifted near the 1st fret. Tips on repair? Stygian Tech: Setup, Repairs and Mods 7 01-04-2006 07:41 AM
how can i repair my fretboard? - it has some scratches ultrazoneman Tech: Setup, Repairs and Mods 3 02-16-2001 12:00 AM
HTML code is On
