Jem 7VWH...What is right, and what is wrong?? - Jemsite
post #1 of 7 (permalink) Old 03-20-2005, 06:33 PM Thread Starter
Red face Jem 7VWH...What is right, and what is wrong??
I have finally got my Jem7VWH and am sooooooo pleased with it!!!
It plays like nothing I have played before and I have no tuning, intonation issues whatsoever!!
The only thing is on looking at my Trem, I realised that it IS NOT parallel with the body and is leaning forward quite a bit...Is this wrong as it plays wonderful?? If not how do I fix it?? why should I fix it if I have no probs??
Also can someone tell me the correct height that my pickups should be??
My neck humbucker is nearly flush with the body, my middle and bridge Pickups are quite High!!!!
I have tried to post pics but it said I am exceeding the File size Limit??
Can someone suffest an easier way to post my pics??
MANY THANKS [email protected]@!!
Rob
robbiedp is offline
post #2 of 7 (permalink) Old 03-20-2005, 06:39 PM
Reviews: 5
Re: Jem 7VWH...What is right, and what is wrong??
Generally, you want the base of the trem to be parallel with the body- so you have plenty of room to pull up and down on the tremelo bar. I doubt that having it improperly set up will damage the bridge though.
Pickup height is a totally subject thing. The farther away from the strings they are, the weaker you will perceive your signal to be. Beware that raising the pickups too close to the strings will hinder your ability to sustain a note since the magnets in the pickups will tend to pull the string to them. Just play with them until you're happy.
For what it's worth, Vai's humbuckers are 4 or 5/16 of an inch from the strings, while the single coil is lowered flush with the pickguard.
jem7vwh is offline
post #3 of 7 (permalink) Old 03-20-2005, 06:43 PM
Does your guitar have a Lo-Pro or an Edge-Pro bridge? If it's a Lo-Pro then don't worry about it being parallel with the body. If it's an Edge-Pro and it plays well, then i still wouldn't worry about it really :S
Andelusion is offline
post #4 of 7 (permalink) Old 03-20-2005, 06:50 PM Thread Starter
Thanks for the advice guys, my guitar has an edge pro on it, and kinda like I said that I am not really seeing any major faults with anything so wasnt sure whether to try and change it or not?
On the other hand, I know onthe tech page on this site and also Rich from Ibanez rules suggest to get it right from the start and to have it parallel??
Not sure what is best for jem??
Will the performance from my edge pro get even better if i adjust it to parallel??
Thanks alot!!!!
Rob
robbiedp is offline
post #5 of 7 (permalink) Old 03-20-2005, 08:26 PM
If your trem is forward quite a bit (as you suggest), you are limiting your dive capability if nothing else. Adjusting the position is a simple task. You just need to tighten the two adjusting screws in the spring cavity and retune. You may have to repeat this a couple times until you get it just right, but it only takes a few minutes, so why not get it right? Whatever you prefer. You can also add another spring, but that is probably too much and should not be necessary.
ryanb is offline
post #6 of 7 (permalink) Old 03-20-2005, 09:13 PM
If you are exceeding the size limit, you´re probably trying to post attachments.
Try http://www.albumtown.com
You can post 50MB of pics there for free.
Uthark is offline
post #7 of 7 (permalink) Old 03-20-2005, 09:21 PM Thread Starter
Unhappy Re: Jem 7VWH...What is right, and what is wrong??
Thanks Dudes!!!
I took the courage to fix it myself and adjust the Screws behind the backplate and after about 15 minutes of retuning it is perfectly intune with the Edge pro sitting nice and parallel!!!
I have one more problem though..... I have ever so slight fret buzz on the low E string from frets 4 til about 15, it doesnt occur on any other stings apart from this one... The action is not very low either so wondering how can I remedy it??
Thanks again?
Rob
robbiedp is offline
bridge pickup , bridge pickups , fret buzz , neck humbucker , pickup height , spring cavity
Did I do something wrong? RockHardGuitars Classified Ads: Guitars and Gear 3 07-26-2012 02:37 PM
WRONG FRETWIRE IN MY 7VWH ARIS Tech: Setup, Repairs and Mods 9 01-10-2012 12:31 AM
Wrong 7VWH body ? I need your help, please. klawn Ibanez JEM, UV, JS & Other Signature Models 15 06-12-2007 04:13 AM
wah is wrong with my wah? lwi Gear, Equipment, Recording & Off Topic 22 02-05-2001 09:53 PM
HTML code is On
