Jem body (old heel) Satch neck? - Jemsite
post #1 of 10 (permalink) Old 01-26-2008, 05:12 PM Thread Starter
If i used a old jem body i have and put a satriani neck on it would it work?
shotgunlew is offline
post #2 of 10 (permalink) Old 01-26-2008, 05:53 PM
Re: Jem body (old heel) Satch neck?
I guess it would work, but you'll have an ugly gap between the 22nd fret and the neck pickup...
jazzedout is offline
post #3 of 10 (permalink) Old 01-26-2008, 06:11 PM Thread Starter
ic ic
post #4 of 10 (permalink) Old 01-27-2008, 04:43 AM
Super Moderator
We've seen pics of a Chromeboy with a JEM green vine neck bolted on there, so I agree it should fit, or could be "made" to fit.
jono is offline
post #5 of 10 (permalink) Old 01-27-2008, 04:23 PM
It will fit but as jazzedout points out, there will be an ugly gap showing. Putting the old-school JEM neck on a chromeboy (or other 22 fret guitar) is easier as you just trim off at the 23rd fret slot.
albee1952 is offline
post #6 of 10 (permalink) Old 01-28-2008, 12:38 AM
Reviews: 5
I dont think it would work as you wouldn't be able to intonate it. Remember the JS is 22 frets 25.5" and the Jem is 24 frets 25.5".
djpharoah is offline
post #7 of 10 (permalink) Old 01-28-2008, 02:58 AM
So, since both are 25.5" scale, intonation won't be a problem... Even if it was 18 frets, or 27 frets since it has the same scale lenght intonation would be just fine...
post #8 of 10 (permalink) Old 01-28-2008, 10:22 AM
Actually, he would be correct, if the heel of both necks came all the way to the end of the fretboard, which, in this particular case, they do not. I believe it's been shown in the past that the overhang on the old school Jem/RG necks is such that the leading edge of the heel ends up in the same spot, relative to the 22nd fret, as a JS's would.
Now an AANJ 24 fret neck, despite having a 25.5" scale, would not intonate on an old-school Jem body, or a JS body, at least not without serious modifications to the heel. Remember, just because a body and neck are both designed for the same scale length, it doesn't mean they're automatically compatible.
djohns74 is offline
post #9 of 10 (permalink) Old 01-28-2008, 01:52 PM
Yeap, you're right. The old square heal is in the exact same position on the old Jems/RGs/JS guitars (relative to the bridge) and that is why these are interchangeable. On AANJ you can not do it, you are right...
post #10 of 10 (permalink) Old 01-28-2008, 02:49 PM Thread Starter
thanks for all the info, if decided that this is a project i will do at a later time or date if ever ( seems like a very large headache )
fret guitar , fret neck , jem neck , neck pickup
Neck for a JEM body metallica81788 Tech: Setup, Repairs and Mods 9 12-23-2007 03:00 AM
Square neck joint on aanj body Jeremiah Tech: Setup, Repairs and Mods 12 11-28-2007 02:28 AM
Jem body and neck jemjr Tech: Setup, Repairs and Mods 0 06-26-2007 11:51 AM
WTB: Jem style body with old school neck pocket Devo Classified Ads: Guitars and Gear 0 06-02-2005 12:20 PM
jem body and neck! nickysplendid Ibanez JEM, UV, JS & Other Signature Models 0 02-16-2005 05:05 AM
HTML code is On
