JEM Cases (molded & shaped) - Help with fitting a JEM case - Jemsite
post #1 of 7 (permalink) Old 06-04-2001, 03:05 AM Thread Starter
I'm well aware that there are countless cases that will fit a JEM or UV that you can get from Ibanez, but they're rectangular and I HATE THAT! I reckon if I'm plunking down two grand for an axe then I can be picky about the hardshell I keep it in. MF sells an SKB case (shaped and molded) that "fits most electric guitars," does anyone know if a JEM will fit in these cases? Thanks for help in advance
Christopher is offline
post #2 of 7 (permalink) Old 06-04-2001, 03:16 AM
If they offer the M100c molded Ibanez case I'd go for that. A Jem actually fits in it better than it does in a UV1000c, it just doesn't offer as much protection. *The SKB will work though, it will fit, but not as form fit as a M100 or UV1000.
Rich is offline
post #3 of 7 (permalink) Old 06-04-2001, 10:10 AM
Also, SKB cases were designed for 22 fret guitars and Jackson style head stocks. The Ibanez head stock will actually poke into the foam and leave about 1/2" between the outside of the case and the tip of the head stock. One good bash on that end of the case and you have a damaged guitar.
I would also go with the M100c.
J>
Vaibanez is offline
post #4 of 7 (permalink) Old 06-04-2001, 04:39 PM Thread Starter
Hey, thanks guys, I'll check out that M100c. Thanks again for the help.
-LZRDKNG
post #5 of 7 (permalink) Old 06-04-2001, 05:30 PM
chromeboy's Avatar
The M100c looks like it'll "wear" better than the 1000 and it does look cooler because of the huge molded Ibanez logo.
chromeboy is offline
post #6 of 7 (permalink) Old 06-05-2001, 03:15 AM
While talking about the M100C hardshell,
Does a RG7-421 fit in there?
GhesQi J is offline
post #7 of 7 (permalink) Old 06-05-2001, 03:22 AM
It will 'fit', but the tip of the headstock will be touching the inside of the case. Same fit for all 7's. Not recomended.
Rich is offline
electric guitar , fret guitar , fret guitars
which molded cases will fit a Jem? Superuser Ibanez JEM, UV, JS & Other Signature Models 11 06-19-2011 10:08 PM
F/S Left-handed Prestege RG J-craft molded case **RARE** Lefty Robb Classified Ads: Guitars and Gear 0 01-12-2009 04:10 AM
Ibanez 540S: Best fitting Hard Shell Case rat All Other Guitars (including Prestige) 6 12-10-2006 07:47 AM
JEM's and UV's now in the molded case ;/// Rich Ibanez JEM, UV, JS & Other Signature Models 57 02-23-2005 10:18 AM
What the... - A UV case...not fitting a UV? Skarekrough Ibanez JEM, UV, JS & Other Signature Models 8 04-24-2002 11:56 PM
HTML code is On
