Jem Neck Crack - Jemsite
post #1 of 3 (permalink) Old 11-16-2004, 12:54 PM Thread Starter
Jem Neck Crack
I'm the original owner of a Jem 777VBK (bought in '90), i have a crack developing in back of the neck where the locking nut anchors are, is this a repair i can make myself or is it something that a tech should do. Is this a common problem with Jem necks? If this is a repair for a tech, how much should it cost to repair??
baldielocks is offline
post #2 of 3 (permalink) Old 11-16-2004, 01:06 PM
This guide by Rich Harris will give you an insight into what is involved, then you'll be able to make up your own mind if it is a job you can take on yourself or not:
http://www.ibanezrules.com/tech/setup/crack_neck.htm
It isn't an unheard of problem with Jem necks, but I wouldn't go so far as to say it was common.
Good luck!
Algiman is offline
post #3 of 3 (permalink) Old 11-16-2004, 01:45 PM Thread Starter
thanks for the info
jem neck , locking nut
Crack in the neck... _MKK_ Tech: Setup, Repairs and Mods 35 05-01-2007 03:57 AM
neck crack isan Tech: Setup, Repairs and Mods 3 12-11-2006 08:12 AM
Jem 555 Neck Crack! Cobra Tech: Setup, Repairs and Mods 5 11-30-2005 06:42 AM
Stress crack on neck joint, or just a finish crack? m0p Tech: Setup, Repairs and Mods 6 11-09-2005 05:59 PM
Neck crack on a 550 slug Tech: Setup, Repairs and Mods 4 03-13-2002 08:30 AM
HTML code is On
