JEM Project - trying to decide if a resto or customization is worth it? - Jemsite
post #1 of 34 (permalink) Old 01-10-2011, 01:15 PM Thread Starter
I picked up a jem7dbk today for only $500 but it's pretty beat up. It's been rattle-canned flat black, some screws missing, horrible plastic diamond-plate pickguard, significant corrosion on some trem pieces (although the main trem parts are ok). Surprisingly the neck is in pretty good shape though. Fretboard and frets need a clean/polish but are in good shape. The neck finish and headstock are great and the hardware on the head has no corrosion at all.
I'm caught between excited and regretful and am not sure whether I should jump right in and go crazy custom (since I'm not sure if it would be worth the $$ to go stock dbk finish) or if I should get my money back (I have 14 days to return it).
Opinions?
Sadly, the pics make the paint look A LOT better than it really is:
http://i1013.photobucket.com/albums/...110_123023.jpg
http://i1013.photobucket.com/albums/...110_123031.jpg
http://i1013.photobucket.com/albums/...110_122946.jpg
http://i1013.photobucket.com/albums/...110_122932.jpg
http://i1013.photobucket.com/albums/...110_123009.jpg
http://i1013.photobucket.com/albums/...110_122917.jpg
EvilEmuOfDoom is offline
post #2 of 34 (permalink) Old 01-10-2011, 01:37 PM
Re: JEM Project - trying to decide if a resto or customization is worth it?
For $500 I'd send that junker back. You can get a nice guitar for that.
musikron is offline
post #3 of 34 (permalink) Old 01-10-2011, 03:54 PM
keep it.
its a good project
nato101010 is offline
post #4 of 34 (permalink) Old 01-10-2011, 04:48 PM
I'd send it back. For what you would spend just to restore it to stock-like levels, you'd be beyond the price of a different DBK.
Takin' a Ride is offline
post #5 of 34 (permalink) Old 01-10-2011, 04:52 PM
Reviews: 4
give it back, save 300 bucks and get a minty dbk or a old 777DY
fwd0120 is offline
post #6 of 34 (permalink) Old 01-10-2011, 04:53 PM
Reviews: 4
The price you would put into making it right would be rediculous, you could easily get a "good" DBK for the price to fix it up!
fwd0120 is offline
post #7 of 34 (permalink) Old 01-10-2011, 04:55 PM Thread Starter
The temptation here is making a cool custom JEM out of it (custom color swirl, etc.) without destroying a nice JEM or using all 3rd party parts. However, as I ad the costs together...
post #8 of 34 (permalink) Old 01-10-2011, 04:56 PM Thread Starter
Also, I didn't realize that the neck on the DBK isn't the same as other JEMs
post #9 of 34 (permalink) Old 01-10-2011, 06:14 PM
Reviews: 3
I guess it really depends if this guitar will work for your project and more important, your budget. If it does then keep it and make it your own, but be sure to take pics and document, but more important. Share your work and results, either way I'm interested in what you are doing so keep this updated.
Pezz is offline
post #10 of 34 (permalink) Old 01-10-2011, 06:39 PM
Show me where you can get either one of those guitars for $800 bucks..........
bob mclaughlin is offline
post #11 of 34 (permalink) Old 01-10-2011, 06:57 PM
Not bagging on ya fwd, but your 2 posts are funny! The only thing he has to do to "make it right" is to just to get a mirrior pick-guard for it. I just dont see were he has to put a lot of money into it for a great Jem at $500, and alot better than the 505.............IMO
post #12 of 34 (permalink) Old 01-10-2011, 07:07 PM Thread Starter
Originally Posted by bob mclaughlin View Post
...The only thing he has to do to "make it right" is to just to get a mirrior pick-guard for it. I just dont see were he has to put a lot of money into it for a great Jem at $500, and alot better than the 505...
It's questionable... You can't really tell in the pics but the paint is absolutely horrible
List of what it needs:
Sanding
Paint and clear
Pickguard
Pickguard Screws
1 Nut screw (of the two that go through the neck)
Trem parts that need actual replacement:
- String lock blocks (6)
- Intonation lock screws (6)
- Studs (2)
- Saddle pipes (6)
- a couple fine tuners
2 pickguard screw holes are stripped
2 trem cover screw holes are stripped
1 Strap screw hole was stripped and filled with "something"
post #13 of 34 (permalink) Old 01-10-2011, 07:34 PM
Reviews: 4
Well, a refinish could cost up to 250-300, a edge pro cost about 200 and a OE cost around 100. and I see DBKs and DYs that are $800 on here, the bay and CL sorta often, I mean, if you are actively looking for one, about once a month or two you can get a great deal! it just takes patience! Right now the prices on the bay aren't great, but wait for summer! I've seen quite a few at 800, but cant link one right now.
fwd0120 is offline
post #14 of 34 (permalink) Old 01-10-2011, 07:46 PM
Sanding
Paint and clear
Pickguard
Pickguard Screws
- Studs (2)
- Saddle pipes (6)
Paint on a DBK? I wouldn't worry about it, the factory paint job isn't something I,d write home about anyway. Stripped screw holes? toothpicks/dowls and wood glue. Trem parts? 50 bucks (for what you wrote down) or a used one from 3-bay and a pickguard. Again, not bad for a great Jem at $500!! just my 2c..........
post #15 of 34 (permalink) Old 01-10-2011, 07:55 PM Thread Starter
If I went with new parts from Rich the estimate comes to:
Guitar - $500
Sanding - Free
Paint and clear - $250
NOS OE Pickguard - $100
Misc Screws - $15
1 Nut screw - $2
String lock blocks (6) - $30
Intonation lock screws (6) - $12
Studs (2) - $24
Saddle pipes (6) - $18 (not 100% sure on this one)
fine tuners - $12
Total = $963 + Various Shipping
So, it isn't too bad considering I kind of like the idea of a project. But, I don't really care for the jem7dbk and would probably want to customize it which would probably add the following:
Swirl Paintjob +$200
Pyramid Inlay $200?
Matching Headstock $100?
Evo and Evo2 pickups $150
So, now I'm looking at $1500-1600 and this is my dilemma...
jem7dbk , project
RG550 customization: which one? AlaskaBat Tech: Setup, Repairs and Mods 4 05-01-2010 03:00 PM
is my jem project worth anything? carbons2k Ibanez JEM, UV, JS & Other Signature Models 9 07-09-2009 10:18 AM
whats it worth RG770 project jcmix All Other Guitars (including Prestige) 18 02-05-2009 09:59 PM
3 Hum customization questions Shredragrammaton Pickups & wiring 1 12-14-2008 01:38 AM
Customization Suggestions kirk Tech: Setup, Repairs and Mods 9 03-18-2001 08:49 PM
HTML code is On
