Jem Serial # Question - The FAQ is not clear on this...Pleas - Jemsite
post #1 of 7 (permalink) Old 09-22-2001, 06:03 PM Thread Starter
My Jem 77FP has a serial number of 060186 on the neck plate. *What year was it made? I looked at the FAQ but it states that a '96 would start with 96xxxx. What year does 06xxxx belong to? Thanks.
Atx88 is offline
post #2 of 7 (permalink) Old 09-22-2001, 08:28 PM
site founder 0% owner
jemsite's Avatar
The FPs get a little confusing because they have the old heel joint when the AANJs (and serial #s on headstock) long ago replaced it. Does your FP have a serial # on the back of the headstock? If not i'd assume this is a 1996 model (highly probable) unless there is reason to believe it's a 1990 model (less likely) ...glen
jemsite is offline
post #3 of 7 (permalink) Old 09-22-2001, 08:32 PM
That is an odd plate #. If no serial # on the headstock logic says it's a 90, but a 60k 90' plate, odd.
Rich is offline
post #4 of 7 (permalink) Old 09-22-2001, 10:49 PM
Step 1- Check how the p/u's are attached:
•Early FP's were pickguard-mounted.
•Later FP's were body-mounted.
That should get you into the right decade, then.....
Step 2- Check number location:
•If there's a number on the back of the headstock, THAT is your serial number (use it for dating, warranty registration, etc.). *
•If there is only a heel joint plate, THAT is your serial number (use it for dating, warranty registration, etc.).
Kevan is offline
post #5 of 7 (permalink) Old 09-23-2001, 04:19 AM Thread Starter
Thanks to all for your kind help. The PU's are body mounted and the #060186 is on the Jem neck plate so I guess it is a '96?
It is my first Jem and is a great player but I am not totally satisfied with the sound since the previous owner put a double whammy in the bridge position. I couldn't find much info on this PU - any comments on its compatibility with a JEM 77FP? *
Atx88 is offline
post #6 of 7 (permalink) Old 09-23-2001, 12:09 PM
I need to add this:
According to Ibanez, if you have TWO numbers on your guitar (one on the neck plate *AND* one on the back of the headstock), then you should use the number on the headstock for dating, warranty registration, etc.
The Double Whammy is a decent hi-gain pickup. *I'd replace it with either the stock PAF-Pro, or another JEM-type pickup (Evolution, Breed). *
But that's just me.
Kevan is offline
post #7 of 7 (permalink) Old 09-23-2001, 06:49 PM
I was under the impression that the plates after 1990 starts with 060, 160 or 260. This means that the 6 doesn't have anything to do with the year at all so '96 might be a wild guess.
Then again I might be very wrong...
SalemB is offline
bridge position , jem neck , neck plate
Clear coat question pwsusi Tech: Setup, Repairs and Mods 22 02-27-2014 07:39 PM
Question about 2k clear coat. Mskrad Tech: Setup, Repairs and Mods 3 06-02-2013 09:06 PM
A swirl clear coat question, and some others thedonutman Tech: Setup, Repairs and Mods 5 01-02-2009 07:24 PM
headstock decal clear over question andrewsfury Tech: Setup, Repairs and Mods 4 01-02-2009 07:16 PM
Yet another Clear Coat question... GuiltySparc Tech: Setup, Repairs and Mods 4 05-21-2008 08:53 AM
HTML code is On
