JEM setup problem - Jemsite
post #1 of 6 (permalink) Old 01-20-2005, 04:08 PM Thread Starter
JEM setup problem
I just got my first Jem (woo!) and during the process of setting it up, I hit a snag: if I get the trem angle right and the action where I want it, the whammy bar hits my volume knob!
Any advice? I thought about bending the bar a bit, but that seems like it could be asking to break the bar.
keithb is offline
post #2 of 6 (permalink) Old 01-20-2005, 04:30 PM
Re: JEM setup problem
Put a shim in the neck pocket. That will raise the neck and you will have to raise the action. This means the bridge will also be raised and your whammy bar will not hit the volume knob. (Raising pickups will probably be required)
You might be able to bypass shimming it if there is a way to adjust the height of the bar. I don't remember if there is though.
Kontalonis is offline
post #3 of 6 (permalink) Old 01-20-2005, 07:14 PM
i had the same thing on my jem and my rg , i took a pair of mole grips a duster wrapped round the bar and used some pressure, it didnt break, , i leave that one up to you, i have done it before and not snapped any but i may just be lucky, the other way is change the knobs for strat type , hey i know thats not realy everyones cup of tea though.
Bezial is offline
post #4 of 6 (permalink) Old 01-20-2005, 08:44 PM Thread Starter
My solution was to wrap a rag around the bar, grab it with some pliers, and give it a lil pressure. Clears the volume knob fine now
keithb is offline
post #5 of 6 (permalink) Old 01-20-2005, 09:38 PM
acoustic1991's Avatar
Reviews: 3
Don't worry about breaking the bar; I just rebent a left handed arm to make a spare right handed one (please don't ask!! LOL).
Josh
acoustic1991 is offline
post #6 of 6 (permalink) Old 01-21-2005, 12:36 PM
yeah I had to bend the bar on my jem and RG.. make sure if its a lopro you take the bushings off
IbanezroadstarII is offline
Please Help with annoying setup problem nickf All Other Guitars (including Prestige) 1 03-07-2012 03:31 PM
Setup problem al3x Gear, Equipment, Recording & Off Topic 1 02-28-2007 01:20 PM
Re-occuring problem with rig setup Nick Lee Gear, Equipment, Recording & Off Topic 3 08-31-2004 12:09 AM
New Radius! BUT a small setup problem... jallen Tech: Setup, Repairs and Mods 11 01-07-2004 08:00 PM
Setup problem (need a little help here guys) Predator Tech: Setup, Repairs and Mods 2 01-01-2003 05:48 PM
HTML code is On
