Jem spring tension? No Divebombs! - Jemsite
post #1 of 2 (permalink) Old 08-13-2010, 08:55 AM Thread Starter
Hello!
I recently purchased a used ibanez jem7vwh in tokyo and im in the process of breaking it in. Today while playing i noticed that divebombs seem to be impossible while depressing the bar on the edge pro. The pitch lowers significantly, but the strings do not slacken enough for divebomb sounds. Also, the string tension seems to be unusually high compared to my other guitars, maybe this is all in my head though. While bending strings it seems like i have to use an extra amount of effort to bend up a full step. The bridge is setup slightly above neutral position with 3 springs in the back. The bridge is an edge pro on a 2009 jem vwh. Please help!! Thank you!
JJLipton is offline
post #2 of 2 (permalink) Old 08-13-2010, 11:09 AM
Re: Jem spring tension? No Divebombs!
Maybe it's just strung up with a higher gauge of string they you're used to?
AxeHappy is offline
ibanez jem , jem7vwh jem77v
Edge III Spring Tension Issues dreadshreadclown Tech: Setup, Repairs and Mods 6 02-13-2009 06:45 PM
Spring Tension Advice the80sroklej Tech: Setup, Repairs and Mods 0 06-14-2007 07:41 PM
string tension and spring tension choubix Tech: Setup, Repairs and Mods 4 06-11-2007 03:21 PM
Spring Tension on my RG aliqamar Tech: Setup, Repairs and Mods 8 04-11-2007 06:00 AM
Adding spring tension on trem... Dr Mindcrime Tech: Setup, Repairs and Mods 6 09-26-2004 12:00 PM
HTML code is On
