JEM Tone Control - Jemsite
post #1 of 10 (permalink) Old 01-31-2018, 05:05 PM Thread Starter
JEM Tone Control
What happens when you have the volume on 10 and turn the tone control down to zero on your JEM?
h4ck.b0x7 is offline
post #2 of 10 (permalink) Old 01-31-2018, 05:14 PM
Super Moderator
Re: JEM Tone Control
It loses the treble content of the sound and sounds more creamy/muffled
jono is offline
post #3 of 10 (permalink) Old 01-31-2018, 06:03 PM Thread Starter
Sorry for the stupid question, I didnít want to lead the conversation by giving other details. My tone control cuts all volume when itís on 0. Not a big deal but that means I have to tear open the electronics and figure out what is grounding when itís not supposed to be.
Iíve only ever used Fender & Gibson guitars and wasnít sure if it was an Ibanez quirk.
post #4 of 10 (permalink) Old 02-01-2018, 01:21 AM
Super Moderator
I figured there was a deeper question there, and no, it's not supposed to do that.
jono is offline
post #5 of 10 (permalink) Old 02-01-2018, 11:30 AM Thread Starter
Have any of you guys seen this occur in the past? It shouldn't be hard to track down but I just figured I'd ask.
post #6 of 10 (permalink) Old 02-01-2018, 01:56 PM
Super Moderator
In about 1997 I didn't buy a second hand green dot Universe that had this fault, so it definitely does happen
jono is offline
post #7 of 10 (permalink) Old 02-01-2018, 03:41 PM Thread Starter
This is the only guitar I have that I didn't have any plans to rewire or replace electronic components in. It shouldn't be a big deal, I would rather just play the thing as opposed to having to open it up. I spend all day as and Engineer, I don't always feel like doing it when I get home.
post #8 of 10 (permalink) Old 02-02-2018, 11:42 AM Thread Starter
I was thinking more about it last night and I realized that one of the first things I did after receiving it was remove the protective plastic from the pickguard. When I did this I had to remove the knobs and I took the nuts and washers off the pots one at a time so as not to leave torn remnants of the protective plastic around the nuts. While tightening the tone control nut I speculate the pot turned and inadvertently grounded the outside lug.
post #9 of 10 (permalink) Old 02-02-2018, 01:54 PM
probably this, exactly. Just check you grounds and check the tone pot and make sure its not grounded out against the body if there is any shielding paint.
dickicker is offline
post #10 of 10 (permalink) Old 02-03-2018, 01:25 AM Thread Starter
I thought I should update this thread to say that the issue was exactly what I expected. The pot had turned when I tightened it and grounded the outside lug against the body. I aligned it back where it should have been and everything is right as rain.
Do all JEM's have plastic skirted volume/tone control knobs? chasingpeace Ibanez JEM, UV, JS & Other Signature Models 3 02-05-2011 10:30 PM
Jem tone control upgrade review pjmguitarist Ibanez JEM, UV, JS & Other Signature Models 13 06-20-2008 09:59 PM
Do you use the tone control? TequilaKing Polls 13 01-07-2008 05:44 PM
Tone control mod? EnigmaUV7 Tech: Setup, Repairs and Mods 4 01-02-2004 08:11 PM
Removing the tone control ytseman Pickups & wiring 6 01-02-2003 01:45 AM
HTML code is On
