JEM555 tremolo swap recommendation ? - Jemsite
post #1 of 8 (permalink) Old 12-14-2010, 10:10 PM Thread Starter
I'm changing the lo trs ii , i 've read that an original floyd rose would be a direct swap but i can't afford that now. i'm thinking of a floyd rose special ... would that be nice ? i can spend up to $100 so i don't know if i have any other option besides that one or a licensed floyd rose
Resurrection is offline
post #2 of 8 (permalink) Old 12-14-2010, 10:51 PM
Reviews: 98
Re: JEM555 tremolo swap recommendation ?
Get a used Edge--you can usually find one for under$ 100
Slight body routing is required, but it's a very easy job. There's a tutorial over at projectguitar.com
AlaskaBat is offline
post #3 of 8 (permalink) Old 12-14-2010, 10:54 PM
Reviews: 6
yeah what Alaska said, check into a Edge. I snagged a Edge bridge off of ebay recently for less than $100. You can find them just check around.
Swirled777 is offline
post #4 of 8 (permalink) Old 12-15-2010, 12:30 AM
Reviews: 98
We just had a few in the classifieds here, too!
post #5 of 8 (permalink) Old 12-15-2010, 06:24 PM Thread Starter
Ok I'll try to buy one of those then, I hope it's no problem that I'm living in Spain right now ...
And thank you, I found the tutorial :
http://www.projectguitar.com/tut/trs2lopro.htm
But the routing idea doesn't sound very attractive ... I mean I don't think I have the tools to do that ... at least the trem post spacing is the same ?
post #6 of 8 (permalink) Old 01-02-2011, 11:10 PM
I puted an edge on mine:
http://images.orkut.com/orkut/photos...d9gJxToWOc.jpg
Claudio Passamani is offline
post #7 of 8 (permalink) Old 01-03-2011, 02:03 PM
If you have a dremel, set it up and take your time - you'll be fine :-)
Rayzor is offline
post #8 of 8 (permalink) Old 01-03-2011, 02:03 PM
Originally Posted by Claudio Passamani View Post
Nice Job!
Rayzor is offline
jem 555 , lo-trs ii
Similar Searches
Ibanez JCRG10
JCRG10-
JCRG10
jcrg10*
Tremolo Swap sleepyone Tech: Setup, Repairs and Mods 7 11-22-2008 07:59 PM
jem555 swap for line6 flextone111 rob777vdy Gear, Equipment, Recording & Off Topic 1 09-25-2007 08:23 PM
jem555 lo-trs 2 swap extremist777 Tech: Setup, Repairs and Mods 5 11-16-2005 04:17 AM
Can I swap the tremolo arm??? Ghiddra Ibanez JEM, UV, JS & Other Signature Models 2 09-29-2005 11:44 AM
Peavey head tube swap- your recommendation germX Gear, Equipment, Recording & Off Topic 4 09-14-2002 10:15 AM
HTML code is On
