JEM7V Trem Problem - Jemsite
post #1 of 2 (permalink) Old 07-12-2010, 02:50 PM Thread Starter
JEM7V Trem Problem
Hi Guys,
I have Ibanez Jem7V which I purchased from new back in 2003, however I am having a little problem with my Lo-Pro trem unit.
The trem is a push in version, however at the surface, where you insert the arm, there is a sort of inner ferrule which looks like a circle with 2 slits cut out of it opposing sides.
For some reason, this ferrule now seems to want to rotate as well when the trem arm is rotated. This is causing the trem arm to pivot in the slot making accurate trem usage and the new replacement trem arm bushes I put in useless.
Can you tell me what I can do you rectify this?? Is it just a matter of tightening it or something more intricate?
Cheers
Baz
bazman1uk is offline
post #2 of 2 (permalink) Old 07-12-2010, 04:42 PM
Re: JEM7V Trem Problem
Sounds like this may be your problem- http://www.ibanezrules.com/tech/setup/loose_holder.htm
Jeminizer is offline
jem7v , problem , trem
JEM7V-WH - trem not even / one side higher than the other JulianH Ibanez JEM, UV, JS & Other Signature Models 5 12-11-2009 05:43 PM
Jem7v Trem Problem BlakeJem7v Ibanez JEM, UV, JS & Other Signature Models 22 05-29-2009 06:09 PM
Jem7v floating Trem Tension SlickXQ Tech: Setup, Repairs and Mods 7 07-04-2003 10:51 PM
Jem7v problem Chriscec Tech: Setup, Repairs and Mods 4 07-01-2003 05:54 AM
UV777BK trem problem - I think it is a problem (shrug) Scoff X Tech: Setup, Repairs and Mods 5 09-21-2001 12:59 AM
HTML code is On
