JEM7V-WH - trem not even / one side higher than the other - Jemsite
post #1 of 6 (permalink) Old 12-11-2009, 06:28 AM Thread Starter
Hi There!
I just got a brand new JEM7V-WH and I'm really curious about one fact:
The two sides of the trem (left and right, near the high e and near the low e string) are not even (relative to the body) - they are leveled differently!
-> Near the high E string, the trem is routed deeper into the body, on the low E string, the trem isn't routed as deep.
Is this normal?
Regards,
Julian
JulianH is offline
post #2 of 6 (permalink) Old 12-11-2009, 06:54 AM
Re: JEM7V-WH - trem not even / one side higher than the other
perfectly normal, don't worry. that's because usually the high-E sits lower than the low-E, so, the trem is set lower on that side.
nuno is offline
post #3 of 6 (permalink) Old 12-11-2009, 07:28 AM Thread Starter
Hi! Thanks!
However, a few more "discussion points":
1. I have two Prestige-RGs with EdgeZero Trem - the EdgeZero doen't "feature" the height / level difference. Why?
2. How much height/level difference between the low and high e string would you consider "normal"?
3. Do you have some pics of your own trem "setup" or a page where this "height difference" is explained (with pics and so on..)?
Thanks!
Regards,
Julian
JulianH is offline
post #4 of 6 (permalink) Old 12-11-2009, 08:12 AM
differences in posts height are normal, not mandatory. it depends on many factors, like the relationship between the neck and the body, neck pocket, action, trem angle and whatever.
circa 1.5/2.0mm? never measured.
nuno is offline
post #5 of 6 (permalink) Old 12-11-2009, 11:27 AM
Hi! Thanks!
Julian
Because the Z series of trems use a ball-bearing in a ring, as apposed to a knife edge. A ball-bearing would bind and stick/scratch if you had it at an angle in the post. where as a knife edge design gives you some play to put it in higher on one side than the other
thesimo is offline
post #6 of 6 (permalink) Old 12-11-2009, 05:43 PM
Hub
EdgeZero is not ballbearing, you're thinking of the ZR I and II
Hub is offline
edge , jem7v , level , not even , tremolo
Jem7v Trem Problem BlakeJem7v Ibanez JEM, UV, JS & Other Signature Models 22 05-29-2009 06:09 PM
neck keeps moving side to side brothersnowgone Tech: Setup, Repairs and Mods 6 08-07-2006 04:22 AM
Bolt/thread size on Edge Pro trem block side? caprile Tech: Setup, Repairs and Mods 6 03-07-2005 11:01 AM
Jem7v floating Trem Tension SlickXQ Tech: Setup, Repairs and Mods 7 07-04-2003 10:51 PM
Angling the trem, bass side higher, causing problems? DoctorCrunch Tech: Setup, Repairs and Mods 6 01-21-2003 04:47 PM
HTML code is On
