JS1 - nob issue - how do you make them stay attached? - Jemsite
post #1 of 5 (permalink) Old 02-10-2012, 12:03 PM Thread Starter
Hey there guys -
So, I bought a used JS1. The guitar was shipped using a fed-ex type service and it arrived just fine. During transit, both of the volume and tone metal nobs came off the posts.
Typically, I have seen a small screw to tighten nobs on the pots. This guitar's nobs have no screw and I'm having a terrible time getting the nobs to stay put.
I dont want to press them to hard, and I dont want to damage the guitar.
Help and advice please....
Thanks -
asg
asg420 is offline
post #2 of 5 (permalink) Old 02-10-2012, 12:12 PM
Re: JS1 - nob issue - how do you make them stay attached?
If there is no screw just press them in. I assume the posts have a little grove, if so than you can press these together slightly. Make sure if you do you use a rag between the pliers and the posts to not damage the ridges.
But usually a little hard press should suffice
dragsternj is offline
post #3 of 5 (permalink) Old 02-10-2012, 03:21 PM
If the knobs wont stay put you want to put a screwdriver in the slot (if you have one) and just slightly open the slot .
Zoot is offline
post #4 of 5 (permalink) Old 02-10-2012, 06:34 PM Thread Starter
will try and get back to you. I hope it works. Sucks playing a "new" guitar without nobs :-(
Thanks for your help.
asg420 is offline
post #5 of 5 (permalink) Old 02-12-2012, 05:19 AM
I put a dab of superglue on the top of the posts of mine, which works for a while until it fails, then needs to be cleaned off and reapplied.
onguitar is offline
js1
Attached tuner linuxpenguin Gear, Equipment, Recording & Off Topic 11 02-14-2011 12:48 PM
FS: RG1527RB body - pics attached Jaden Classified Ads: Guitars and Gear 1 07-19-2008 03:19 PM
Look what I got! (stay away 56k) ZOMB13 All Other Guitars (including Prestige) 18 05-13-2007 06:48 PM
How can i make the lo pro edge trem stay in tune? kalashnikov All Other Guitars (including Prestige) 32 02-01-2006 05:27 AM
Make a NICE fixed bridge 7 - and make that an S too... ChrisReedSmith Comments to Ibanez 2 03-12-2001 04:52 PM
HTML code is On
