JS100 BRIDGE question - Jemsite
post #1 of 11 (permalink) Old 04-21-2011, 10:07 PM Thread Starter
Hey guys..im a newbie so forgive me if this info is available on this site already. I am currently customizing a JS100 (only have the body for now)and was wondering what type of tremolo would fit properly with this guitar-exactly what are my choices? Thanks for your help~~
unseenforcez is offline
post #2 of 11 (permalink) Old 04-21-2011, 10:49 PM
Reviews: 6
Re: JS100 BRIDGE question
Depending on the model. Lo-TRSII equipped guitars, an Original Edge will fit very well, with minimal sanding. Newer JS100's or JS20S's with Edge III tremolo's won't accept the Edge as easy. Body routing is different on the newer ones. You can make an Edge fit the newer ones, just a little more work needs to be done. Haven't tried a Lo-Pro Edge but I know they are different from the Edge's.
Now for other trems, you can use a Floyd Rose or Gotoh Floyd to fit.
Swirled777 is offline
post #3 of 11 (permalink) Old 04-23-2011, 02:37 AM
Reviews: 11
lo pro's and edge's have same width dimensions. Exactly the same actually. Cant see how an edge/lo pro would fit and the other wouldnt
linuxpenguin is offline
post #4 of 11 (permalink) Old 04-23-2011, 11:00 AM
Reviews: 6
yeah I wasn't sure, I've never had a Lo-Pro Edge bridge that wasn't a 7 String. So I wasn't sure of the dimensions for a 6 string Lo-Pro Edge bridge. I've only had original Edge experience with 6 strings, and Lo-Pro's on 7's. But that's good to know the dimensions are the same.
post #5 of 11 (permalink) Old 04-23-2011, 02:54 PM
Reviews: 11
same width, 4 5/8" inches wide, but what my concern would be the orientation of the tremolo. The Lo pros sit flat while the edge's sit higher up. Lo pro may have some interference with a js100, not positive. Edge would be the safe bet regardless and is, imo, the better tremolo anyway
post #6 of 11 (permalink) Old 04-23-2011, 09:55 PM
If you fit any edge trem weather it be original edge or lopro or whichever, you will need to rout the neck pocket 2mm deeper. Otherwise everything ends up set too high eg. Tremendous post heights , pickups poking out like skyscrapers. Look at anyone who has done the trem conversion. Pickups poking out.
Have a look at my JS build thread. It explains it all and demonstrates it. Although my build included an rg570 wizard 1 I still had to rout to get the neck set in correctly. Also if you want correct fitting of the edge style trems, some body routing of js100 body is required.
And don't forget term posts and studs to get rid of the god awfull js100 studs
SP2333 is offline
post #7 of 11 (permalink) Old 04-23-2011, 10:06 PM
RGTFanatic's Avatar
Edge Pro should be a direct drop in, even the studs will work. I DO however recommend upgrading to Lo-Pro locking studs while the trem is out. It only requires a little drilling (and filling the hole in first if your anal like me)
RGTFanatic is offline
post #8 of 11 (permalink) Old 04-23-2011, 11:00 PM
Reviews: 6
That's funny, mine didn't stick out like a skyscraper.
post #9 of 11 (permalink) Old 04-25-2011, 12:58 PM
Can someone shoot out models that came with an Original Edge stock bridge?
Bluesman001 is offline
post #10 of 11 (permalink) Old 04-25-2011, 02:05 PM
Reviews: 11
too many to list....
post #11 of 11 (permalink) Old 04-26-2011, 02:12 PM
I have an early 540S and the bridge from a JS100 is a little too small...what would for the 540s?
TECHNOROCKTRONIC is offline
bridge , custom , customizing , ibanez , js100
whats a js100 bridge pickup output???? j-o-d Tech: Setup, Repairs and Mods 0 01-22-2007 12:03 AM
JS100 Bridge Problems hylianhero27 Ibanez JEM, UV, JS & Other Signature Models 9 12-19-2006 05:21 PM
Should I get a new bridge for a Strat or should I buy JS100? Xavier 7 Ibanez JEM, UV, JS & Other Signature Models 1 06-10-2004 06:55 PM
Evolution bridge H into a JS100 Uglifruit Pickups & wiring 2 08-07-2003 07:16 AM
HTML code is On
