JS100 string clamps - Jemsite
post #1 of 3 (permalink) Old 11-02-2009, 10:33 AM Thread Starter
JS100 string clamps
Hey all,
Just looking for some advice again if that's ok. Go gentle.
I said in a previous thread about my JS100 making a horrific creak/crack noise when I depress the whammy bar, well it turns out that this is entirely down to the string clamps on the nut. I can only assume that they have worn out, although I did replace the screws as the allen key holes were slightly worn out (did a sneaky switch with my old RG370DX which I was selling on.)
Is it possible that the screws are causing this? they fit just fine into the locking nut as far as I can see and feel.
Failing this, does anyone know if it is hard/easy to get hold of a new set of string clamps? I don't really want to have to buy a new bridge or something just for threee little bits of metal (although strangely when I got my bridge replaced a few years ago it didn't come with new string clamps...)
Thanks for taking the time to read my post and I'll be eagerly awaiting any responses.
deonblaster is offline
post #2 of 3 (permalink) Old 11-02-2009, 12:13 PM
Re: JS100 string clamps
It should be pretty easy to get new clamps. Just go into any shop and ask for them. I know the place I go always has them in stock. They are pretty cheap too.
yellowshirtguy is offline
post #3 of 3 (permalink) Old 11-03-2009, 07:52 AM
Make sure the nut is tightened snugly (but not super tight) onto the neck before buying new nut pressure pads.
Also, are the screws you switched the same length? If they are now longer, you could be bottoming out resulting in not being able to fully tighten down the pressure pads.
nlinny is offline
js100 , string clamp
How tight should I tighten the string clamps on the trem? fastonebaz Ibanez JEM, UV, JS & Other Signature Models 10 05-15-2009 08:58 AM
string tensions on my js100 wastedyears Ibanez JEM, UV, JS & Other Signature Models 3 08-06-2005 05:27 PM
WTB- Universe locking nut clamps, screws + askewniverse Classified Ads: Ibanez JEM/UV Guitars 2 04-20-2005 11:58 AM
Autographed JS100 for sale/trade for 7 string RG_76 Classified Ads: Guitars and Gear 1 03-28-2005 11:17 PM
locking tuning posts / clamps stephan.keuneke Tech: Setup, Repairs and Mods 1 02-07-2004 12:05 AM
HTML code is On
