JS1000/1200 string spacing - Jemsite
post #1 of 7 (permalink) Old 09-27-2009, 07:32 PM Thread Starter
Hi,
Over the years I've had a few JS1000's and 1200's, but gradually sold them as I tended to prefer the slightly wider string spacing offered by RG and Jem necks. However now that I dont own a JS anymore (and sold my Jem) I'm interested to get a couple of measurements to compare against a few other guitars I own.
I'm interested in the overall width of the strings, when measured from low E to high E just after the nut and before the 1st fret.
So far I've measured the following guitars that I have to hand (ignoring my Universe!):
Ibanez Masa: Actual nut width = 42.50mm, string width after nut = 36.15mm
ESP M-II: Actual nut width = 41.44mm, string width after nut = 35.45mm
Fender delux american strat: Actual nut width = 42.00mm, string width after nut = 35.57mm
The reason I ask is becase of the 3 guitars, when playing between the 1st and 9th frets I am most fluid and precise on the electro-acoustic Masa, despite its high action, from 9th down its the ESP. Amazingly, that 0.7mm makes quite a difference.
If anyone out there has an accurate vernier/micrometer and could measure a JS for me I'm be most grateful, and the same measurement on an RG would be useful also! I suspect the JS might have a similar string spacing to the ESP.
Many thanks,
Chris
chris101 is offline
post #2 of 7 (permalink) Old 09-28-2009, 01:46 PM
Re: JS1000/1200 string spacing
Here ya go:
both equiped with 042-009's
JS1200ca (2007) : Actual nut width = 42.08mm, string width after nut = 36.15mm
RG8470 J custom (2007) Actual nut width = 43.03mm, string width after nut = 37.20mm
The RG makes me play a bit faster/preciser as well for now.
Silverburst is offline
post #3 of 7 (permalink) Old 09-28-2009, 03:49 PM Thread Starter
Thanks for the info. Out of interest I measured my Universe, just from low E to high E, thats a 'cramped' 35.5mm!
chris101 is offline
post #4 of 7 (permalink) Old 09-29-2009, 09:29 PM
i measured my js-2000 and got slightly different measurements. 42.44 mm nut width and with 042-009 strings i got 36.44 string width at the nut. i have begun guitar building with a js replica that i made myself. the first neck i made started out with 42mm width at the nut but after shaping and sanding it got a little smaller. i too prefer a slightly wider neck so i guess i learned something from the first attempt.
woodman300 is offline
post #5 of 7 (permalink) Old 09-30-2009, 04:22 AM
It's the first time I've actually measuerd this difference in these guitars, and have to say I also have to work a little harder on the JS. But you universe 35.5 ?? that's really small, I can't remember that my UV777bk was that small, it felt like a big ruler
post #6 of 7 (permalink) Old 09-30-2009, 02:21 PM Thread Starter
Yep, check it again and its 35.5mm, probably explains why I canít do perfectly clean pull offs everytime from the 1st fret without clipping the adjacent strings on that guitar.
I'm suprised at how much wider the JS string spacing is compared to the ESP, maybe the radius on the JS mkaes it feel tighter to me than it really is.
chris101 is offline
post #7 of 7 (permalink) Old 09-30-2009, 04:12 PM
Should be the opposite no ? the radius is a lot smaller on JS's, which would pull the strings a bit away from each other like they are on a cylinder. I've always prefered flatter radiuses myself, but I just can't step away from a JS being primarily a Satch fan when it comes to Ibanez signature models.
string spacing
Gotoh Floyd string spacing vs Edge Pro 2 string spacing Andy Mclaughlan Tech: Setup, Repairs and Mods 2 05-07-2009 10:37 PM
FT Ibanez PGM301 for a JS1000/1200 or Jem in UK rockguitar4ever Classified Ads: Guitars and Gear 0 12-09-2008 01:31 PM
JS1000 or 1200? wandereruk05 Ibanez JEM, UV, JS & Other Signature Models 38 06-06-2008 06:02 AM
WTT/WTB: My JS700 or 540R for JS1000/1200 zoner Classified Ads: Guitars and Gear 0 06-08-2007 10:14 PM
Petrucci's GP6 vs. Satriani's JS1000/1200? Inzane All Other Guitars (including Prestige) 1 04-28-2007 04:50 AM
HTML code is On
