JS1000 Breaks Strings - Jemsite
post #1 of 13 (permalink) Old 12-13-2003, 10:07 AM Thread Starter
Hi guys,
i bought a brand new 03 JS1000BTB a month ago. it was setup perfectly and everything is ok its a sweet guitar, i love it. but till i write this every string from high to low e broke, and thats not normal, is it? what can i do to stop this? avery few days a string breaks and 5 minutes ago it was the low e string that broke.......
what can i do?
thanks
phienix is offline
post #2 of 13 (permalink) Old 12-13-2003, 10:21 AM
whoa a low E string broke? where did it break? at the contact point at the saddles or at the nut?
EXCrosslink is offline
post #3 of 13 (permalink) Old 12-13-2003, 10:36 AM
what strings do you use?
.009 gauge i reckon... but what brand?
saTa is offline
post #4 of 13 (permalink) Old 12-13-2003, 11:18 AM Thread Starter
they all break at the intonation point at the bridge
i use 0.09 d'addarios
phienix is offline
post #5 of 13 (permalink) Old 12-13-2003, 11:23 AM
you're referring to the saddles i reckon.
i suggest to loosen them, take them off and draw on there with a smooth pencil to make the saddles smoother and less hurting (damn... hard to say in english... check your icq, german :P)
saTa is offline
post #6 of 13 (permalink) Old 12-13-2003, 07:44 PM
You're tuned to E, right?
MehYam is offline
post #7 of 13 (permalink) Old 12-14-2003, 06:06 AM Thread Starter
Sure!
phienix is offline
post #8 of 13 (permalink) Old 12-14-2003, 07:35 PM
And that's E below middle C, right?
MehYam is offline
post #9 of 13 (permalink) Old 12-14-2003, 08:38 PM
Well are they breaking when you use the bar or what? I can break strings once a weak if i play alot, but my saddles are in no way sharp, just that if im playing alot im practicing with the whammy bar alot and when im practicing with it alot im breaking alot of strings *ill shut up now*
sniperfrommars1 is offline
post #10 of 13 (permalink) Old 12-15-2003, 01:15 AM Thread Starter
It usualy happens when using the bar. If it would be one of the higher strings that break.......but the low d and e string? i'm waiting for the a-string to break ^^
phienix is offline
post #11 of 13 (permalink) Old 12-15-2003, 04:46 PM
Ive broken all the strings at one time or another its most directly attributed to wear. What kind of strings are you using?
post #12 of 13 (permalink) Old 12-15-2003, 08:36 PM
breaking strings
It may be that you havent tightened the retaining screws enough.
Thats happened to me before, if I don't tighten the screw, a few
strums later, BOINGG! the string just pops out. You can be sure if there
is no remnant of the string still sticking out of the vibrato block.
rosster is offline
post #13 of 13 (permalink) Old 12-16-2003, 04:45 AM Thread Starter
Im using D'Addario 0.009 Strings.
And no, the String is really broke, its not popped out.
**** i dunno what to do now, ill call my dealer and ak him...
phienix is offline
higher strings
Tight End Bridge problems, anyone think it breaks strings? CoversMonkey All Other Guitars (including Prestige) 3 01-05-2011 05:10 PM
JS1000 w Heavy Gauge (13.) strings? Jazzmatazz Ibanez JEM, UV, JS & Other Signature Models 6 12-02-2009 07:21 PM
js1000 or js1200 strings big_paul_ski Ibanez JEM, UV, JS & Other Signature Models 12 07-14-2009 10:20 PM
what strings to use on my js1000 btb? Aeolian555 Ibanez JEM, UV, JS & Other Signature Models 11 03-22-2009 10:28 AM
JS1000 Factory Strings GlassPrison2112 Ibanez JEM, UV, JS & Other Signature Models 1 10-18-2004 05:51 PM
HTML code is On
