JS1000 Questions - Jemsite
post #1 of 4 (permalink) Old 04-15-2008, 11:24 PM Thread Starter
JS1000 Questions
Hi all,
Just received my JS1000 off a guy from CT. I live in Western Canada.
Anyway, I had already typed 3/4's of a longer post when I accidental pushed the wrong buttons an lost the email so I am going right to the quetions:
It is strung with 10's and the previous owner had it tuned to "D". In your guys' estimation, will I need to add another Trem spring to the 3 already there?
The volume knob/shaft was stupidly pulled out by me. I added a small strip of tape to the shaft to secure it into the pot. I realize after the fact that it is supposed to pull, which it doesn't, to activate the high pass filter. Am I screwed and have to get a replacement pot or is there any way to fix the existing pot so it switches?
Really appreciate some help. guys....
Thanx,
Jim
vmann is offline
post #2 of 4 (permalink) Old 04-15-2008, 11:50 PM
Re: JS1000 Questions
Shouldn't need another spring unless they're heavy bottom 10's. The plastic clip on the shatft was probably already broken but it is not fixable, only replaceable.
Rich is offline
post #3 of 4 (permalink) Old 04-17-2008, 08:48 PM Thread Starter
Smile Re: JS1000 Questions
Thanks, Rich
I got the trem adjusted with 3 springs as you suggested. I do have a fair amount of experience with Floyd's but I was starting to get concerned when the adjustment screws were close to running out of threads.
Do I just replace the shaft on the volume knob or do I have to replace the pot??
Also, could you suggest a place to purchase these parts as I also need 1 lock nut clamp.
Much appreciated!!
Thanx,
Jim
vmann is offline
post #4 of 4 (permalink) Old 04-17-2008, 10:01 PM
email me
Rich is offline
high pass filter , lock nut
If I buy a used JS1000....questions??? Axe Chemist Ibanez JEM, UV, JS & Other Signature Models 1 03-31-2008 08:54 AM
JS1000 questions satchmo Ibanez JEM, UV, JS & Other Signature Models 9 10-17-2007 05:10 PM
few JS1000 questions jimbojim Ibanez JEM, UV, JS & Other Signature Models 5 01-27-2003 10:09 PM
1998 Black Pearl JS1000?!? Really a 1999?? Rich, perhaps? Dominick Furlano Ibanez JEM, UV, JS & Other Signature Models 5 08-21-2002 08:50 AM
Ibanez JS Questions!!! - Please answer these questions I hav Ibaman Ibanez JEM, UV, JS & Other Signature Models 6 09-08-2001 02:10 PM
HTML code is On
