js1000 whammy help! - Jemsite
post #1 of 20 (permalink) Old 12-30-2007, 07:31 AM Thread Starter
Exclamation js1000 whammy help!
ive got a js1000btb..the bar has always been like this and ive heard of some techniques to fix this but am not to sure..so id ask you guys..
my bar seems incredibly loose...whenever i let it go..it would full swing round..
i would like it to be exactly were i leave it..so if i finish using it...it would stay were i left it...but is still easy to move...
like the way steve vai's..any suggestions?
the trem is the old edge pro if anyone was inquiring
millzy is offline
post #2 of 20 (permalink) Old 12-30-2007, 07:48 AM
Super Moderator
Re: js1000 whammy help!
Edge Pro or Lo-Pro edge?
In truth I'm not sure if that makes any difference. Is it this collar that's loose or is it the bar inside the collar. My JS1000 has the Lo-Pro edge and the bar is fine in that so I'll talk about the Lo_pro trem for now.
There's a collar into which you push the bar that is tightened with a nut on the underside of the trem.
If it's the bar in the collar that's loose, you can get new white bushings for the trem arm that should stiffen it up a bit, or you can paint the end of the bar in nail varnish (aparently) to make it slightly thicker and thus have more friction against the spring.
Hope that helps
jono is offline
post #3 of 20 (permalink) Old 12-30-2007, 07:54 AM
Reviews: 10
i think someone on this forum mentioned before that they use tape (electricians or duck tape) wrapped round once to solve the problem.
richard1973 is offline
post #4 of 20 (permalink) Old 12-30-2007, 11:49 AM Thread Starter
thanks guys...
the trem is the edge pro...
its the actual trem inside the collar as you can hear it squeaking from drastic moves. good thing is ive got two new brushings so ill try everything
firstly ill try the electrical tape so thanks richard ill try it out...and get back
millzy is offline
post #5 of 20 (permalink) Old 12-30-2007, 11:57 AM
JJEMMER777's Avatar
Originally Posted by millzy View Post
thanks guys...
Try the plumbers tape (thin) Wrap it once (or twice) in the slots and install the new bushings over it. Works like a charm
JJEMMER777 is offline
post #6 of 20 (permalink) Old 12-30-2007, 12:05 PM
Or if you cant be assed doing that, take the bushings off the arm, paint a couple layers of varnish underneath where the bushings go, put the bushings back on, and there ya go
twooos is offline
post #7 of 20 (permalink) Old 12-30-2007, 12:09 PM
JJEMMER777's Avatar
And quick fixes aside, lets not forget this:
You cannot tighten it without removing the trem. (which really is no biggie)
post #8 of 20 (permalink) Old 12-30-2007, 01:14 PM Thread Starter
i tryed the electricans/plumbers tape..and it worked well..but its got that feel of ..'im gonna have to change it after a few days'.
once i placed a thin layer around the base of the arm it wouldnt fit in..so i placed on small 5mm strip over the brushings and that seems to have worked..but it was 5mm in breadth and about 1.5cm long..just placed over the brushings..
millzy is offline
post #9 of 20 (permalink) Old 12-30-2007, 01:18 PM
JJEMMER777's Avatar
Wrap it in the slots "under" the bushings. Don't wrap too much or the arm will not fit in
It really does work well! So do the other methods mentioned.
It's all about increasing ~girth~
post #10 of 20 (permalink) Old 12-30-2007, 01:25 PM Thread Starter
ahh i think that must be my problem..i simply wrapped the tape over it..
but the brushings must come off..and is it simply placing a layer on the 'brushing bit' and then putting the brushings on over the tape?
millzy is offline
post #11 of 20 (permalink) Old 12-30-2007, 01:27 PM
JJEMMER777's Avatar
Yeah, wrap a bit in the slots (directly on the bar) and then fit the bushings over it. It'll be a tight fit, but that is what you want
post #12 of 20 (permalink) Old 12-30-2007, 01:27 PM
jb4674's Avatar
Reviews: 18
Smile Re: js1000 whammy help!
Precisely.
Jimmy
jb4674 is offline
post #13 of 20 (permalink) Old 12-30-2007, 01:32 PM Thread Starter
ok..ill try this then..
in your opinions, when is the appropriate time to change brushings?
millzy is offline
post #14 of 20 (permalink) Old 12-30-2007, 01:45 PM
JJEMMER777's Avatar
Just change the tape peroidically as needed and you won't have to change the "brushings" as you call them, lol.
In other words, you can re-use the old bushings
post #15 of 20 (permalink) Old 12-30-2007, 03:13 PM Thread Starter
ahh right, here we go..
i tried these methods..the old electricians tape first, covering the brushing slots..it worked but i found the trem to still be slipping but not as drastically..
i tried a few more times but it was always the same so i just used the method that worked for me the first time..with a small strip places over the brushings
millzy is offline
arm holder , pro edge , steve vai , trem arm
WTT Black Edge whammy bar for a Black Lo TRS whammy bar RG_76 Classified Ads: Guitars and Gear 5 07-11-2006 06:03 PM
Changing Whammy settings Freaker Tech: Setup, Repairs and Mods 0 05-27-2006 06:27 AM
jem 7v vs js1000 red5 Ibanez JEM, UV, JS & Other Signature Models 34 12-07-2003 12:04 AM
js1000 or Jem 7v :) red5 Ibanez JEM, UV, JS & Other Signature Models 8 11-30-2003 09:22 PM
1998 Black Pearl JS1000?!? Really a 1999?? Rich, perhaps? Dominick Furlano Ibanez JEM, UV, JS & Other Signature Models 5 08-21-2002 08:50 AM
HTML code is On
