JS1200 help please - Jemsite
post #1 of 11 (permalink) Old 06-05-2010, 03:54 PM Thread Starter
JS1200 help please
Hi, last week I bought an ibanez js1200. I have never had a guitar with a floyd rose before but am aware of the basics. I tuned my guitar up properly and it was fine but now there is a lot of fret buzz which was not there before I tuned up. The action is at an almost identical level but the trem is not sitting parallel (flush) to the body as it was before. Could this be the whats causing the buzz. Should I adjust the tension to make it flush again, should this get rid of the fret buzz?
If this is not going to help please tell me what to do.
Thanks, Joe
joejuts19 is offline
post #2 of 11 (permalink) Old 06-05-2010, 05:05 PM
Super Moderator
Re: JS1200 help please
Which way is the bridge sitting? Tail up or tail down?
What tuning do you have the guitar in and have you changed string guages?
jono is offline
post #3 of 11 (permalink) Old 06-05-2010, 05:29 PM Thread Starter
The bridge is sitting tail up I think (I can now see under the bridge more as it's higher up). I tuned it standard but when I got it it was almost in slack tuning it was so far out. I haven't changed the strings but don't know what gauge they are.
Thanks for reply
post #4 of 11 (permalink) Old 06-07-2010, 11:28 AM
Reviews: 59
The bridge should be flush with the body as has been said. To really diagnose the buzz problem, where are you getting buzz? With open strings? Only on some frets? All over?
Check out Rich's Tech page on ibanezrules.com and you'll find additional information on setups to help you out.
smooth55 is offline
post #5 of 11 (permalink) Old 06-07-2010, 05:02 PM
jb4674's Avatar
Reviews: 18
The bridge shouldn't be flushed with the body. The Knife Edges should be parallel to the body regardless of what the overall position of the bridge is once the knife edges are parallel with the body.
Jimmy
jb4674 is offline
post #6 of 11 (permalink) Old 06-08-2010, 03:25 PM
Reviews: 59
oops, flush equals parallel to me sometimes
smooth55 is offline
post #7 of 11 (permalink) Old 10-24-2010, 11:30 AM
you should check out rick's page at ibanezrules... he has a very thorough guide on how to set up and maintain trem equipped guitars.
Seriously this guy has helped me A LOT check him out
noairplayguitar is offline
post #8 of 11 (permalink) Old 10-25-2010, 03:49 PM
He goes by Rich
moebius is offline
post #9 of 11 (permalink) Old 10-25-2010, 08:01 PM
JS 1200 have a real Floyd Rose trem? or what?
o3o0o is offline
post #10 of 11 (permalink) Old 10-26-2010, 04:15 AM
Licensed Floyd systems. You won't find n OFR on a stock Ibanez.
Ibanez strive to improve on the original design, and have very successfully.
(JS1200 introduced 2004)
(Edge Pro 2003-2009) (Original Edge 2010...)
II Hamish II is offline
post #11 of 11 (permalink) Old 11-25-2010, 03:02 PM
Make sure the gauge of strings is the same as your last set.If they are then the term angle may be off a bit.
Like somebody said earlier in the thread make your your trem sits level to the body , all most parallel.
kael_jo is offline
edge pro , fret buzz , js1200 , tension
WTB JS1200 (UK) Dazza1004 Classified Ads: Guitars and Gear 0 12-01-2006 06:33 AM
F/T. VBK for JS1200 waz Classified Ads: Ibanez JEM/UV Guitars 1 11-19-2006 11:33 AM
js1200 beozjs1200 Ibanez JEM, UV, JS & Other Signature Models 5 05-29-2006 04:28 PM
Just got the JS1200 Scott Ibanez JEM, UV, JS & Other Signature Models 17 09-08-2004 04:25 PM
JS1200 Kontalonis Ibanez JEM, UV, JS & Other Signature Models 8 07-17-2004 05:03 PM
HTML code is On
