JS1200 Low E buzz...help! - Jemsite
post #1 of 7 (permalink) Old 10-10-2011, 01:47 PM Thread Starter
Alright guys
Just bought my first JS1200 and have found that the low E buzzes when i play notes on frets 1-4. I dont remember this happening on other guitars, any ideas?
Cheers
Chris
strattST is offline
post #2 of 7 (permalink) Old 10-10-2011, 02:28 PM
Re: JS1200 Low E buzz...help!
TheFreak777 is offline
post #3 of 7 (permalink) Old 10-10-2011, 03:04 PM
Reviews: 98
Yep--just some slight adjustment needed--follow the guides at ibanezrules.com
Also, for technical issues--post them in the Tech section for proper exposure. If it's a pickup or wiring issue--post it in the Pickups and Wiring section.
Another great resource is the SEARCH feature. You can find answers to the very common issues, like yours, right in the search results. Be careful to not type in too many specifics, or you'll get a ton of unrelated threads. In this case, you'd type in "fret buzz," or "buzz" and see what you get.
AlaskaBat is offline
post #4 of 7 (permalink) Old 10-10-2011, 03:18 PM Thread Starter
Cheers for that. It's not the pickups its just the low e string touching the frets, but none of the other strings.
strattST is offline
post #5 of 7 (permalink) Old 10-10-2011, 03:50 PM
Reviews: 98
I know it's not the pickups--I was just letting you know about the 2 tech sections we have for questions like this. I'm sure you'll have it solved soon.
post #6 of 7 (permalink) Old 03-23-2012, 05:16 AM
Loosen the neck a little.
DramaQueenDie is offline
post #7 of 7 (permalink) Old 03-23-2012, 11:14 AM
Umm, have you seen this neck? You must have, otherwise how could you really suggest he adjust the relief in his neck?
musikron is offline
js1200
fret BUZZ BUZZ BUZZ lotusroadster Tech: Setup, Repairs and Mods 10 09-23-2010 04:18 PM
Tried Out Js1200 ashton Ibanez JEM, UV, JS & Other Signature Models 7 02-25-2006 07:23 PM
Fret buzz on the Js1200 Stoph Ibanez JEM, UV, JS & Other Signature Models 4 08-11-2005 04:41 PM
advice needed for strange fret-buzz on my UVGR - nasty buzz Superuser Tech: Setup, Repairs and Mods 8 02-19-2002 04:35 AM
HTML code is On
