JS2000CG FX Edge bridge? - Jemsite
post #1 of 2 (permalink) Old 03-30-2003, 11:57 PM Thread Starter
If I recall, the JS2000CG has this special FX Edge bridge. Supposedly it is a fixed bridge that has the same dimensions as the Edge. Would it be possible to drop in an FX Edge into, say, an RG560 that has an Edge, without further modifications/routing?
NOTP is offline
post #2 of 2 (permalink) Old 03-31-2003, 12:07 AM
This has been discussed previously, but no- the FX Edge is NOT retrofittable due to the mounting studs that it uses. Basically, it's part stop bar tailpiece, part Edge. I'm sure it could be done with some routing, but...you'd be better off just blocking the existing tremolo
vaijem777 is offline
Closed Thread
edge bridge , fixed bridge
WTT: my Gold Schaller FR bridge for your Black Lo Pro Edge or Edge bridge supergirl20_06 Classified Ads: Guitars and Gear 2 08-05-2011 05:57 AM
FS Ibanez Joe Satriani JS2000CG supergirl20_06 Classified Ads: Guitars and Gear 0 01-13-2009 04:29 AM
WTT Ibanez JS1000BP for AT300AV, JS2000CG, or MM JPM!! Smitty Classified Ads: Guitars and Gear 4 01-02-2007 02:42 PM
JS2000CG - Edge FX mysterious brooding 3rd adjustment thing zoner Ibanez JEM, UV, JS & Other Signature Models 1 08-28-2002 09:27 PM
D-Tuna on a JS2000CG? Scott 74 Ibanez JEM, UV, JS & Other Signature Models 15 07-17-2002 03:24 PM
HTML code is On
