JS6 Headstock and SN question. - Jemsite
post #1 of 17 (permalink) Old 06-11-2018, 04:46 PM Thread Starter
I just received a JS6 however although the headstock looks to be correct it does NOT have the "JS Series" Logo below Ibanez. When I measure the nut width I come up with 1 5/8" not even close to 1 11/16".
The SN is: J 001303 and was listed as a 1992 JS6.
The Hog body looks correct but I'm NOT a JS expert. It also has #6 written, faded, on the bottom of the headstock facing down.
Could this be a very early one without the JS Logo, a proto type or ? ? ?
Any info would be greatly appreciated.
Thank you !
GoghVan is offline
post #2 of 17 (permalink) Old 06-11-2018, 04:58 PM
Re: JS6 Headstock and SN question.
You'd have to post pictures but headstock logo's are over the clear and many times when they get scuffed or scratched up people just remove them.
The nut should still be 42mm, although with the amount of hand finishing anything is possible. But if you want to know if the neck is correct you'll either have to post pictures or pull the neck and look at the heel stamps.
Rich is offline
post #3 of 17 (permalink) Old 06-11-2018, 05:19 PM Thread Starter
Thanks Rich, the headstock is aged darker but NO wear on the front logo. The JS Series is just not there.
If I've done this correctly here are pics.
GoghVan is offline
post #4 of 17 (permalink) Old 06-11-2018, 05:23 PM
There is definitely wear on the logo, I'd just assume the JS Series was removed, although you can never rule out factory screwup. The #6 is somebodies rack marking so they could see what guitar it was at a glance offstage IMO, although just looking at it should be the biggest clue, pro techs and amateurs like to do stuff like that.
I do have that plate number in my database as a JS6 that was on ebay years ago. There are plenty of them in that 1300 range so I doubt it precludes any of them, although that is the lowest number I have on record.
Rich is offline
post #5 of 17 (permalink) Old 06-11-2018, 05:26 PM Thread Starter
I must be doing something wrong. I can drag the pic to the correct spot, it loads, but then disappears. Perhaps it's too large at 1.5MB?
GoghVan is offline
post #6 of 17 (permalink) Old 06-11-2018, 05:34 PM
site founder 0% owner
jemsite's Avatar
you should pull the neck and verify. that is a very sloppy logo looks reapplied. Retainer bar seems very close to the machine head also.
https://reverb.com/item/988021-ibane...-only-345-made
jemsite is offline
post #7 of 17 (permalink) Old 06-11-2018, 05:34 PM Thread Starter
Strange it went through but I didn't see the pics until I reloaded the page.
Thanks Rich. The clear coat where the JS Series should be is smooth and the Ibanez logo is raised. The seller who shall remain nameless said "There is also a hint of someone having written “#6” on the side of the headstock. I can neither confirm nor deny what that means, or who this guitar belonged to at some point. "
It'a had a recent refret but still needs some attention to play as well as it should.
I guess the neck heel should tell me more.
Thanks for your help!
GoghVan is offline
post #8 of 17 (permalink) Old 06-11-2018, 05:44 PM Thread Starter
These markings are all I see. Nothing on the other 3 sides of the heel.
GoghVan is offline
post #9 of 17 (permalink) Old 06-11-2018, 05:45 PM
I see nothing questionable but condition. Neck back has been sanded, etc.
http://www.ibanezrules.com/images/gallery/js6.jpg
I you attached a picture, it didn't.
Rich is offline
post #10 of 17 (permalink) Old 06-11-2018, 06:00 PM Thread Starter
Thanks guys ! I'm not really concerned with a few nicks etc. because I wanted a player but for a refret (that's what I was told) it should play much better than it does. I'm pretty good with setups and have a USA Tele neck on a Marc Rutters body that plays super. This isn't there yet and it came from builder who said the setup was great. Came with 9's I like 10's and it's still not where it should be. It could be a refret but it will need a level and crown from about the 10th fret up mostly on E,B, G and a bit on D.
GoghVan is offline
post #11 of 17 (permalink) Old 06-11-2018, 06:02 PM Thread Starter
I don't know why it didn't post but the heel does have a Red "K" then J S - 6 spread out with a "T" near one of the mounting holes.
GoghVan is offline
post #12 of 17 (permalink) Old 06-11-2018, 06:10 PM
Confirmed.
just because it was refret doesn't mean the job was done well.
Rich is offline
post #13 of 17 (permalink) Old 06-11-2018, 06:38 PM Thread Starter
Thanks Rich.
A number of years ago I purchased a JS1600 from you. I was in a few bands where it didn't fit "the look" so I wound up selling the guitar about 2 year into that because I rarely used it. Big mistake. It was mint and your setup was superb. IIRC I put 10's on it and some minor adjustments and it played flawlessly.
I've noticed that this JS6 also has a small glue patch on the treble side of the body where they typically crack at the heel.
Not thrilled with that.
Thanks again.
GoghVan is offline
post #14 of 17 (permalink) Old 06-12-2018, 08:44 AM
It's just a touch up, probably done with a paint pen. I've touched up logos before. You can make it look pretty good if you try.
Removing the "JS Series" wouldn't be tough either as it would be sitting on top of the finish. I removed a PGM Series from a PGM30 headstock.
Takin' a Ride is offline
post #15 of 17 (permalink) Old 06-12-2018, 09:24 AM Thread Starter
What bothers me the most is the glued neck pocket crack. I didn't purchase another JS model about 6 months ago because of the same thing. I think it devalues the guitar and scares buyers if you ever want to sell it in the future.
I'm not sure how I want to handle this.
This is the second JS model in a month that I've had where the guitar had issues that were either undisclosed or misrepresented.
GoghVan is offline
js6 joe satriani
SN on a USRG30 shreddyknight All Other Guitars (including Prestige) 1 11-24-2008 04:04 PM
where to find info on SN's if stolen? finstah All Other Guitars (including Prestige) 4 05-15-2007 12:32 PM
Jem Body SN ? bluealien Ibanez JEM, UV, JS & Other Signature Models 1 04-19-2005 01:17 PM
Les Paul Custom SN 81731630 Mint - Can anyone give me an app Lange All Other Guitars (including Prestige) 8 03-02-2002 06:05 PM
Wanted: *JS6 - Looking to buy a JS6 Bew Ibanez JEM, UV, JS & Other Signature Models 1 01-02-2001 04:09 PM
HTML code is On
