Kennydoe's string-stretching secrets *revealed*!!! - Jemsite
post #1 of 6 (permalink) Old 08-24-2002, 01:51 AM Thread Starter
kennydoe's Avatar
There have been a few threads lately with people wondering how to keep their guitars in tune after changing strings.
Obviously this is all covered on ibanezrules.com and on the tech section here at Jemsite, but i thought i'd share my own method which works quite well for me.
Step One:
I change from the top down (E-B-G-D-A-E(-B on the UV)). I unlock the trem only on the strings I'm changing. I don't know if this makes a difference in anything, but that's what I do. (I put the pad back on, but don't lock the ones that i've finished)
Step Two:
While sitting in front of the TV, stretch the high E-string first by placing your fourth finger on the 19th fret and bending up a whole step, then back down, then do the 15th fret, then the 13th, etc. Retune the guitar, repeat 2-3 times. It will come back less and less out of tune each time you do it. Repeat on all strings. It doesn't matter what show you're watching.
Step Three:
Sit in front of the TV and noodle - lots of bendy blues licks. no shredding (ever). Do this without the bar - you don't need the temptation. Tune every couple of minutes. Once the guitar is satisfactorily in tune and pretty much staying in tune, lock the trem. It wont' stay in tune if you use the bar a lot if it's unlocked no matter how hard you try, so don't bother.
Step Four:
After about an hour of playtime, you might find the guitar is in tune with itself, but has dropped a little flat. To correct this, tune the guitar to itself (even if it's flat). Then, without unlocking the trem, tighten the trem claw screws in back about 1/8-1/4 turn (depending on how out of tune it is). Once it's very close, use the fine tuners to tune it. If it comes back sharp, loosen the trem screws a little (split the difference).
I change my strings every 2-3 weeks depending on how heavy my gig schedule is. Also see my post on 'pre-breaking' strings to extend the life of strings if you use a floyd rose trem.
here => http://www.jemsite.insomnia-vhosting...pic.php?t=1098
It's about the 6th post down.
Good luck everyone!
~Kenny
kennydoe is offline
post #2 of 6 (permalink) Old 08-24-2002, 02:03 AM
Re: Kennydoe's string-stretching secrets *revealed*!!!
~Kenny
This is good advice, I cheat them that way as much as allowed. I's recomend tighten the claw a hair at a time though, like 32nd/16th turns till it's close. A 1/4 turn is enough to change the trem angle slightly so I'll take what the angle allows me before I unlock and use the tuners.
Rich is offline
post #3 of 6 (permalink) Old 08-24-2002, 05:16 AM
cerealk's Avatar
can you still do this if you are not in front of the TV?
cerealk is offline
post #4 of 6 (permalink) Old 08-24-2002, 07:50 AM
WMerkert's Avatar
are you back from holidays Simon?
WMerkert is offline
post #5 of 6 (permalink) Old 08-24-2002, 12:12 PM Thread Starter
kennydoe's Avatar
It is the most important part, yes. Hard to explain to you commoners, but it does indeed make a difference.
~K
kennydoe is offline
post #6 of 6 (permalink) Old 08-24-2002, 12:13 PM
cerealk's Avatar
that's Dr. Commoner to you Kenny!
cerealk is offline
claw screws , floyd rose , floyd rose trem , trem claw
String stretching? PrinceAlice Tech: Setup, Repairs and Mods 3 05-13-2008 03:50 PM
Cool Nordegg Featurette and ... string stretching :) chlamy Tech: Setup, Repairs and Mods 20 05-25-2007 09:08 PM
This one's for ~kennydoe-boy~ ;) JJEMMER777 Off-topic / Miscellaneous 21 02-09-2007 10:37 AM
String stretching messed with my tremolo :( heeby1 Ibanez JEM, UV, JS & Other Signature Models 4 04-05-2005 09:38 PM
Excessive stretching of High-E string on lo-pro BluewookieJim Tech: Setup, Repairs and Mods 8 02-23-2003 09:00 AM
HTML code is On
