Low action, tremolo pull ups and pickup height... - Jemsite
post #1 of 9 (permalink) Old 05-19-2011, 12:01 PM Thread Starter
Question Low action, tremolo pull ups and pickup height...
When I try and do crazy Vai pull ups with my Edge, the strings always end up hitting the bridge pickup. I've tried lowering the pickup, but to get the problem to go away the pickup loses too much output and starts to sound thin and plinky. I'd really rather not change my action (but I will if it's the only solution)
Any tips?
oilpit is offline
post #2 of 9 (permalink) Old 05-19-2011, 12:05 PM
Re: Low action, tremolo pull ups and pickup height...
Changing your action prob only solution I suspect!
bucket_bot is offline
post #3 of 9 (permalink) Old 05-19-2011, 12:20 PM
what guitar is it, what pickups, and are they active?
Mozi is offline
post #4 of 9 (permalink) Old 05-19-2011, 12:22 PM Thread Starter
77BFP, Evos
oilpit is offline
post #5 of 9 (permalink) Old 05-19-2011, 01:32 PM
Reviews: 12
I could be wrong but you might need to shim the neck to give the bridge/neck some angle, i'd reccomend reading up the tech section of ibanez rules it's really informative, and will give you info you should know before fidling with anything...
I personally have my action high so dont get any choking from the bridge, but im sure theres a way to compromise with the bridge/neck and pickups....
Good luck
ozzuk is offline
post #6 of 9 (permalink) Old 05-19-2011, 01:58 PM
Reviews: 98
Active pickups will have no effect on the problem listed--it's a clearance issue.
AlaskaBat is offline
post #7 of 9 (permalink) Old 05-19-2011, 02:00 PM
The height of the pickup has to be higher than the neck, so ozzuk may be right. What is the action like now? I'm guessing high. The strings have to clear the pickup and, if on a pull up of the bar, the strings contact the pickup first, the distance between the neck and strings is greater than the distance between the pickup and strings.
therightjem is offline
post #8 of 9 (permalink) Old 05-19-2011, 06:44 PM
Reviews: 4
Sounds silly but, Are the knives level??
fwd0120 is offline
post #9 of 9 (permalink) Old 05-20-2011, 05:37 AM
Reviews: 98
Good point, sometimes the obvious eludes us.
Edge Pro Pull Ups/Action nkri Tech: Setup, Repairs and Mods 1 09-23-2010 01:03 AM
Action Height TroelsRasmussen Tech: Setup, Repairs and Mods 2 08-05-2007 12:17 PM
Action Height: What is yours at? waylay00 Tech: Setup, Repairs and Mods 7 04-16-2007 09:32 AM
Low Action and Whammy Bar Pull-Ups guitarman13 Tech: Setup, Repairs and Mods 7 01-24-2007 11:51 PM
String Action, Pickup Height, Neck Bow, etc. Drache713 Tech: Setup, Repairs and Mods 4 11-10-2002 03:46 PM
HTML code is On
