Low E String strange problem on JEM7VWH - Jemsite
post #1 of 5 (permalink) Old 08-10-2010, 08:55 AM Thread Starter
Hi,
I just bought a brand new (2009 though with edge pro) JEM7VWH.
The guitar is plainly awesome, however I have a problem with my low E string : from 15th fret down to 24th it doesn't sound clean, like if there were several notes, compared to high E.
I've changed the strings (9s btw), tried to up/low pups and trem, without luck.
I even brought the guitar to two differents stores for setup, and they could not resolve it.
Any idea ?
I don't know what else to do...
Thanks !
Ayerown is offline
post #2 of 5 (permalink) Old 08-10-2010, 09:14 AM
Re: Low E String strange problem on JEM7VWH
What you're describing is probably just a side effect of the large gauge of the string and the short vibrating length it has at the higher frets. Almost all guitars sound worse on the low E from the 15th fret upwards.
littlephil is offline
post #3 of 5 (permalink) Old 09-21-2010, 12:06 PM
True, why would you need to play much on the low E way up there? move it to the A string man.
Suga D is offline
post #4 of 5 (permalink) Old 09-21-2010, 12:19 PM
Reviews: 9
It is just what happens when you play that high up on a floppy string.
You could put heavier strings on but I've always had a weird thing against putting anything other than 9's on a JEM. It's like putting off-road tyres on a Ferrari or something.
Lowering the pickup should help a wee bit, but I'd probably change how you pick it, try a couple of different dynamics. Like Suga D said though, play a different string, lol.
Fun111 is offline
post #5 of 5 (permalink) Old 09-21-2010, 01:52 PM Thread Starter
I was actually trying to play the attitude song, the main riff at the octave, that is 15th, 16th, 17th frets on the E string, that's how I discovered it.
Didn't know it was normal... but looks like it is.. Thanks
Ayerown is offline
jem7vwh , string
Strange Humming from my Jem7vwh :S Ralph khoury Tech: Setup, Repairs and Mods 6 12-25-2006 08:28 PM
Strange Problem - Need Help ASAP! waylay00 Pickups & wiring 5 12-09-2006 03:55 PM
Strange Problem - Need Help waylay00 Pickups & wiring 0 12-09-2006 01:10 AM
Jem7vwh g string problem unique77 Ibanez JEM, UV, JS & Other Signature Models 16 03-24-2005 11:07 AM
strange happings - what's the problem with this amp! oooo Gear, Equipment, Recording & Off Topic 3 06-10-2001 11:41 PM
HTML code is On
