Low string volume - Jemsite
post #1 of 6 (permalink) Old 12-23-2002, 11:32 AM Thread Starter
Low string volume
Hi!
Anyone having this problem?
I've got a JEM7BSB and the high E string has a lower volume than the other
What do you think?
flyz is offline
post #2 of 6 (permalink) Old 12-23-2002, 11:36 AM
Adjust your pickup heigth to compensate.
musicdr is offline
post #3 of 6 (permalink) Old 12-23-2002, 11:36 AM
Re: Low string volume
Originally Posted by flyz
Hi!
What do you think?
yep, i had this problem on my RG550 with a non-F-spaced FRED pup. I just raised the pup screw for that string to balance it out.
spacenuke is offline
post #4 of 6 (permalink) Old 12-23-2002, 11:38 AM Thread Starter
yeah I tried that one but it doesn't get much better
flyz is offline
post #5 of 6 (permalink) Old 12-23-2002, 12:44 PM
Get your pickup as close as possible to the strings without the fretted string hitting them. This is your pickup height.
Then adjust the polepieces one by one to adjust string-to-string volume.
Turn the high E polepiece counterclockwise, and the ones who sound louder than the others clockwise.
The top of the pole piece should never be below the surface of the pickup, nor should it be more than one-eight of an inch above the surface. Be careful not to turn it too far because it could fall out.
Cheers,
Joten
GhesQi J is offline
post #6 of 6 (permalink) Old 01-01-2003, 07:36 PM
Yes, after following Ghes's suggestion and if it still does not work, then you may have to lower the volume of all other strings to match with the E string of concern.
amt7565 is offline
pickup height
Volume, Volume, 3 way(blade).... hotrod128z Pickups & wiring 7 12-05-2011 06:51 PM
FS: N-Tune Onboard Tuner - Replaces Existing Volume with Volume/Tuner! (new in box) For_The_Love_Of_Jems Classified Ads: Guitars and Gear 5 08-16-2010 07:03 PM
Volume Pot johnnyd529 Ibanez JEM, UV, JS & Other Signature Models 2 05-09-2006 06:07 PM
Bad volume pot? jeff l Pickups & wiring 5 04-16-2003 10:43 PM
7-String Tune-O-Matic? 7-String String Saver Saddles? Drache713 All Other Guitars (including Prestige) 1 12-03-2002 11:27 PM
HTML code is On
