The middle pickup A/B test #1 - i figured it out :) - Jemsite
post #1 of 12 (permalink) Old 04-11-2001, 11:19 AM Thread Starter
kennydoe's Avatar
Okay...I got the little demos into mp3 format (more patience today)
First of all, please pardon all the 'Funk 101" rhythm. *I just wanted to put a bunch of different examples. *Each sample is just under 30 seconds long.
I plugged the guitar straight into board and put a touch of reverb on. *Also added the slightest bit of high end. *i tried to bring the guitar above the track. *I didn't change any settings (other than a little bit of volume) from sample to sample.
Both samples are the '4' position with the middle p'up and the split neck hum.
One is the PAF+Jem Single Coil
One is the PAF+DiMarzio VirtuAL 2
I won't tell you which is which - you decide which sounds better, or if they both sound the same.
Pickup Config #1
Pickup Config #2
If you like this, I'll do the same when the Tom Anderson 7 string P'up comes in. *Let em know if you want to hear that too. *Any suggestions for recording are welcome.
~Kenny
kennydoe is offline
post #2 of 12 (permalink) Old 04-11-2001, 12:48 PM
Ok, I'll play that game! *I definitely feel that sample 1 wins my vote. *To my ears I dont hear much differnce in terms of the pickups tonality, but I think the articulation is superior, more defined and generally more pleasing.
I wouldnt like to say which was which, I would guess that #2 is the Jem, but I would hope that I am wrong
Purplehaze is offline
post #3 of 12 (permalink) Old 04-11-2001, 10:29 PM
Number one seems to have a bit more output provided you used the exact same amp settings and levels on recording. 2 has a more compressed sound and a lower output.
Bamm
bammbamm is offline
post #4 of 12 (permalink) Old 04-12-2001, 01:02 AM
FUn exercise...I agree with Bamm's assessment. *#1 sounds better, but is it just louder? *Seems to have a more crisp tone.
Greg
gkelm is offline
post #5 of 12 (permalink) Old 04-12-2001, 01:37 AM
1 had something there that 2 lacked, my vote is for one.
Noodles is offline
post #6 of 12 (permalink) Old 04-12-2001, 04:10 AM
cerealk's Avatar
I think #1 is the better of the two-more bite!
Cheers
Simon
cerealk is offline
post #7 of 12 (permalink) Old 04-12-2001, 05:22 PM
Definitely #1... just has more character to it.
dacmo is offline
post #8 of 12 (permalink) Old 04-12-2001, 06:02 PM
They both sound good. But #1 all the way!
RSVampire is offline
post #9 of 12 (permalink) Old 04-13-2001, 11:13 AM Thread Starter
kennydoe's Avatar
I regret having plugged the guitar directly into the board, rather than just using one setting on the preamp. *The difference in the demos was not that big, but the difference in real life, I assure you is much bigger.
Everyone picked the Jem single coil (#1) as the one that sounded better. *They were recorded a few days apart and maybe the volume settings were different.
Or maybe you all just like the JEM single better...personal taste, i guess!
According to the specs on the DiMarzio site, the Virtual 2 is 50% hotter than the HS-3 (JEm single coil's equivalent). *I also get a nice 'acoustic' sound from the bridge-middle position. *never got that from any other pickup, including the TX special.
Thanks to all who participated. *I'm sorry i didn't get to do it from my 7 string!
~Kenny
(Edited by kennydoe at 11:15 am on April 13, 2001)
kennydoe is offline
post #10 of 12 (permalink) Old 04-13-2001, 02:28 PM
Oh....I thought that the Jem Single was close to the FS-2.....as I have seen many wiring diagram in old Ibanez site that use FS-2 instead of Jem Single
anyone has detail specification about the Jem Single?
I was planning to replace the JEM SINGLE on my PGM(basswood body) with a HS-2 which is using in my RG(ash body) because I feel that the HS-2 sounds better.....
But I dunno is that it "sound better" because of different woods....
cowcowcow is offline
post #11 of 12 (permalink) Old 04-13-2001, 05:51 PM Thread Starter
kennydoe's Avatar
Kev says HS-3
It similar, not the same. *Each JEM middle matches the hums that surround it, i.e. The one in the DBK matches the Breeds, the 7VWH matechs the Evo, etc.
All I know is that just about anything is better than what's in there.
~Kenny
kennydoe is offline
post #12 of 12 (permalink) Old 04-13-2001, 06:17 PM
the 7vWH has an evo single - or that's what the specs say, and mine sounds brilliant.
~A
anuj is offline
amp settings , basswood body , wiring diagram
JEM/EVO Middle Pickup rickybaby1985 Pickups & wiring 9 01-31-2012 09:25 AM
Middle pickup. Do I really need RW/RP? rdm Pickups & wiring 5 04-15-2008 07:14 AM
Suggestions for new middle pickup RoadstarTOO Pickups & wiring 6 05-24-2004 06:04 PM
Good Middle Pickup the second eye Pickups & wiring 2 10-13-2003 07:34 PM
HTML code is On
