Moving knob position on a 7VWH - Is it possible to repositio - Jemsite
post #1 of 6 (permalink) Old 04-24-2001, 09:35 PM Thread Starter
Hey fellas,
I'm considering getting a 7VWH , but my only concern is the placement of the volume knob. *I currently play an '89 RG570 but the volume knob is always in the way when I do some serious picking. *Any 7V owners have this prob? *Also, is this particular guitar routed in front so that I could reposition the volume pots? (ie get a replacement pickguard with drill holes for the control pots a little bit lower.)
Thanks for your help.
OOPs, sorry, I posted this in the wrong section. *I didn't realize there was a tech section.
(Edited by Drestin Black at 8:44 pm on April 24, 2001)
Drestin Black is offline
post #2 of 6 (permalink) Old 04-24-2001, 10:31 PM
site founder 0% owner
jemsite's Avatar
you could get a new guard with the hole where you like, or drill a new hole in the existing pickguard. i find the vol knob a bit too close for comfort myself. I don't they'll be changing that anytime soon however ... glen
jemsite is offline
post #3 of 6 (permalink) Old 04-25-2001, 12:13 PM
I had the same problem. I thought of replacing the volumn pot with a mini "on/off" switch ("on" pointing down). Then I decided to just pull the volumn pot out of the pick guard, tape the shaft in the full open position and push the pot into the cavity. I am lazy and did not feel like rewiring. Then I filled the hole with a "dummy" pot and replaced the knob.
This method allowed me to have the stock look and it is easily returned to the stock configuration.
big al is offline
post #4 of 6 (permalink) Old 04-25-2001, 03:43 PM
personally i find it in quite a good position, when i'm picking high e my pinky tends to shape itself around it so it also allows me to adjust the vol whilst in mid flow.
I'd say if you really want the guitar it may be worth making that slight right hand adaptation, just see it as another trick in your bag.
Steve
ripl3y is offline
post #5 of 6 (permalink) Old 04-25-2001, 03:44 PM
You could always switch them so the vol takes place of the tone and do as big al has and fill the hole.
Steve
ripl3y is offline
post #6 of 6 (permalink) Old 04-25-2001, 04:18 PM
It bugs me when I rest my hand on the bridge (which is about 75% of the time normally) but only 5% of the time on my 7V because the knob gets in the way. *Even worse is the single coil, that REALLY gets in the way.
lgascoig is offline
volume pots
Wire between toggle and volume knob on JEM 7V has broken off the knob side Hiketsu Tech: Setup, Repairs and Mods 2 11-17-2010 04:22 AM
my tone knob is a volume knob... Homebake Pickups & wiring 12 06-27-2009 02:15 PM
Varying Position of FP Vol knob - a year or production difference? Metallion Ibanez JEM, UV, JS & Other Signature Models 4 06-26-2007 08:18 PM
Could i change the 2 position switch of my RG620x to a 3 position switch? supergirl20_06 Tech: Setup, Repairs and Mods 4 05-10-2007 04:27 AM
Moving the pickup switcher position cowcowcow Tech: Setup, Repairs and Mods 3 04-04-2001 02:17 PM
HTML code is On
